Hi all pardon my newbie status I am looking for advice and any info you guys can give. I need to build a device that can measure in MM the bends in rims so I can record before and after results. I would like to either bluetooth the info to a tablet preferably or a laptop, also while all this is going on could it be live as well. My intent is to find measuring from the inside of the rim the most outer spot at which time I can zero the reading then spin the wheel to find the low spot "point of impact bend" and image that.
At the moment I been using digital dial indicators, which I get excellent results, I build my own wheel fixture and the hydraulic part that works exceptionally well. Being I work at a dealership and use their straightening equipment machine it has a computerized program to straighten the wheel. I built my own due to the fact theirs is not efficient as I would like it to be, in other words painfully slow by comparison. What I do now is take first reading put rim on my device repair it and back on theirs to get a final reading. Nine out of ten times my numbers are better than the programmed tolerances of the machine. I am not going to get this sophisticated a this but need just a reading so see the picture I captured.
Any help would be gratefully appreciated on a shoe string budget too.
Thanks well in advance Best Regards.
