I am build an arduino controlled autonomous drone and i need a way to wirelessly connect to at least 4 arduinos at once and control them now this needs to be able to go past walls.
also i want them to be able to see where they are going so i need a sensor to avoid objects like walls. and if they could know where they are that would be a bonus.
i want 4 of the drones to be controlled from 1 computer. 1 arduino per drone and i want it to be able to detect walls and also have a gyro and acceletrometer
Even if you are capable of writing the rather advanced code for this you have to build the drone first and in itself that is a complex task if you have no experience.
For an autonomous system, I would break it down into multiple sub-systems, each with it's own MCU.
System control
Mechanical control
Guidance control
Fault detection
I may have left something out.
yes i have but i need something that can do more specific things like fly a very specific flight path without going out of it and these systems wont do that very well
