Autonomous robot problem
Hello everyone,
I'm new to this forum and I'm here cause I ran into a problem with my robot.
I started writing some code for it but for some reason it works really well when plugged into my computer, but when I detach the cable and leave the robot alone on its batteries the robot is not doing what it should do anymore. Here's the (rather simple) code I've written for it already.
#define ENABLE_A 0
#define ENABLE_B 1
#define IN1 2
#define IN2 3
#define IN3 4
#define IN4 5
#define trigpin 6
#define echopin 7
#define trigpin2 8
#define echopin2 9
#define MAX_DISTANCE 154
   pinMode(trigpin, OUTPUT);
   pinMode(echopin, INPUT);
   pinMode(trigpin2, OUTPUT);
   pinMode(echopin2, INPUT);
   pinMode(ENABLE_A, OUTPUT);
   pinMode(ENABLE_B, OUTPUT);
   pinMode(IN1,OUTPUT);
   pinMode(IN2,OUTPUT);
   pinMode(IN3,OUTPUT);
   pinMode(IN4,OUTPUT);
long duration, distance;
digitalWrite(trigpin, LOW);
delayMicroseconds(2);
digitalWrite(trigpin, HIGH);
delayMicroseconds(10);
digitalWrite(trigpin,LOW);
duration = pulseIn(echopin, HIGH);
distance = (duration/2)/29.1;
if (distance >= 154 || distance <= 0)
  Serial.println ("nope");
  Serial.print(distance);
  Serial.println("cm");
long duration2, distance2;
digitalWrite(trigpin2, LOW);
delay(2);
digitalWrite(trigpin2, HIGH);
delay(10);
digitalWrite(trigpin2,LOW);
duration2 = pulseIn(echopin2, HIGH);
distance2 = (duration2/2)/29.1;
if (distance2 >= 154 || distance2 <= 0)
 Serial.println ("nope2");
  Serial.print(distance2);
if (distance < 5)
   digitalWrite(ENABLE_A, HIGH);
   digitalWrite(ENABLE_B, HIGH);
   digitalWrite(IN1, HIGH);
   digitalWrite(IN2, LOW);
   digitalWrite(IN3, HIGH);
   digitalWrite(IN4, LOW);
else if (distance2 < 5)
  digitalWrite(IN1, LOW);
  digitalWrite(IN2, HIGH);
  digitalWrite(IN3, LOW);
  digitalWrite(IN4, HIGH);
Is there something wrong with the code, or is there a hardware problem?
Thanks for your help in advance!
Charles
You're gonna catch hell for not 1) using code tags, 2) reading the 'How to use the forum' stickie....
But, what are you gonna serial.print to if you disconnect from the computer (USB)?
This is my first arduino project. I need this robot to work completely on its own. What do you suggest I change then?
Probably a power issue. What are you using for a battery? What is the voltage on the 5v arduino pin when running off of the battery?
What is it supposed to do, and what does it do instead?
zoomkat:
+1
It's very common for people new to robotics to underestimate the amount of power required by small motors.
If you're using a 9V battery used in smoke detectors, don't. They cann't provide enough current for most motors.
Add a signal in the startup section to let you know the program has just started. Turn a LED on and off or something similar. This startup signal is to let you know if your program is resetting. Resets are a common problem with poor power supplies. When a motor attempts to draw more current than the battery can handle, the voltage drops causing a reset.
