Hi Everyone,
I am using an Arduino Uno Board as the microcontroller behind my autonomous project. I am using 4 XL-MaxSonar Pin Out Ultrasonic Range Finders (MB-1200). I am setting Pin1 - low. I want to know how to read the reflected data/pulse.
http://www.google.com/url?sa=t&source=web&cd=1&ved=0CBgQFjAA&url=http%3A%2F%2Fwww.maxbotix.com%2Fuploads%2FMB1200-MB1300_Datasheet.pdf&rct=j&q=mb1200%20datasheet&ei=dszOTZWXO4jYgQe_tIDGDA&usg=AFQjCNFYEQz13sNFrhCtzs2uQ_YnUSmdmg&sig2=9-gHRTBgwxt3VaZpyVPrrg
^ Datasheet for MB-1200
Just out of interest, how do you balance torque with three rotors?
You probably meant: http://www.maxbotix.com/uploads/MB1200-MB1300_Datasheet.pdf
"Pin 2 -MB1200 (PW) This pin outputs a pulse width representation of range. To calculate distance, use the scale factor of 58uS per cm."
You probably want to connect Pin 2 to some Arduino data pin and use pulseIn(dataPin, HIGH) to get the length of the pulse in microseconds. Then divide by 58 to get cm.
