autostart arduino program from sd?
I look for a way to turn on the arduino and it should execute a program from uSD card. So I could change the SD card and start with another program. Especially I would like to autostart the arduino and it should restart even after a power fail and restart the actual program from SD card automatically.
I found a thread “Running a sketch code from sd card?” from 2009:
http://forum.arduino.cc/index.php/topic,3908.0.html
But that ended without a solution. Ther is a full fleged OS - but that needs some expensive touchscreen etc. At least I do not need the overhead of interactivity of an OS.
I could not find some other postings or solution that possibly can fit to that topic? Does eventually somebody know such a solution …?
Is there any solution?
Kind Regards
I guess if you could write your own bootloader that reads the SD rather than reading from USB?
Bitlash would be the way to do that. You would need to write a sketch that implemented all the features available in all of your sketches - the Bitlash script would then contain the application logic and you could install a different script by updating the SD contents.
If you need to actually upload a completely new sketch from the SD card, Bitlash won’t do that and you’d need an SD card bootloader or piggy-back Arduino system. I’m pretty sure Nick Gammon has discussed both of these approaches.
That's exactly the proposal of the thread from 2009 http://forum.arduino.cc/index.php/topic,3908.0.html Obviously that is not such easy because no one has done that yet? I hoped that there has been done some previous work to start at. I just browsed the manual and on page 5 of the manual indeed there is a description of autostart a function at boot. That might be a strting point. Looks easy but sometimes problems might be found in the details.
Concerning the bootloader, the bootloader source one can find at
http://code.google.com/p/arduino/source/browse/#svn/trunk/hardware/bootloaders
If it really is a good idea for a dummy to touch the bootloader? http://forum.arduino.cc/index.php?topic=187931.0
Regards
btwo: Obviously that is not such easy because no one has done that yet? I hoped that there has been done some previous work to start at.
Booting Bitlash off an SD card is a standard feature of Bitlash, so I don't understand why you think nobody has done it yet.
Thank you very much indeed!
That helps a lot!
Regards
