I think I know the answer to this, but I'll ask it anyway:
My project has several relays and other devices that I expect to exceed the current capabilities of my Arduino Uno board, so I plan on connecting a separate 5V wall wart to power the devices independently front the Arduino supply.
Only the GNDs between the Aruino and the wall wart should be connected.
Do not connect the wall wart +5V to the Arduino +5V!
(Unless you are sure the USB cable or the onboard regulator (VIN cct.) is not used)
Yeah, that's what I was thinking. Was just kinda hoping I was wrong! I think I found a trace I can cut on the proto board to separate the two supplies.
If there are two holes (at 1/10th inch) with the trace between, you could put a 2 pin male header in them and short them with a shorting plug later when you need to.
