available memory
i did some test regarding the available memory. here's my code below
#include <math.h>
  Serial.begin(9600);           // set up Serial library at 9600 bps
  int b;
   b=availableMemory();
   Serial.println(b,DEC);
// this function will return the number of bytes currently free in RAM
int availableMemory()
  int size = 1024;
  byte *buf;
  while ((buf = (byte *) malloc(--size)) == NULL)
  free(buf);
  return size;
output is 828
i was wondering what was used to wipe off so many bytes since there is no floating point calculation?
i have another question:let say i have a function (say it takes up 200bytes)with full of floating point calculations in it.And i need to call it quite frequently to update some other functions.will the function use up the 1k sram eventually as it was being called ?
The Serial buffer consumes 128 bytes, the rest is due to the startup code and the sketch.
Whatever dynamic RAM a function consumes will be released immediately after the function returns so It doesn't matter how quick you call it.
thanks for the replies ..i will update this thread again
i had successfully send 4 bytes of command packet to control the WCK servo and it's suppose to response by transmitting back 2 bytes back to arduino.
1)is it the right way to clear the 2 bytes by calling Serial.read() for 2 times?please refers to my code PosSend() function.
2)why i couldn't see the rx led blings or it's too fast for a naked eye?
3)how to optimize my code as the dynamic ram only left 50bytes?
here's my code
#include <math.h>
#define HEADER 0xff
{  char SpeedLevel,ServoID,Position;
   SpeedLevel=0x01; // hex value to represent the speedlevel
   ServoID=0x00; // hex value to represent the servoID
   Position=0x80; // any value from 0-255(byte/hex)that represents position
   Serial.begin(115200);           // set up baudrate at 9600 bps
   char x,y;
   x=PosSend( ServoID,  SpeedLevel, Position);
   y=availableMemory();
   Serial.println(y,DEC);
char PosSend(char ServoID, char SpeedLevel, char Position)
  //char Current;
  SendOperCommand((SpeedLevel<<5)|ServoID, Position);
  Serial.read();//read first byte
  Serial.read();//read second byte
  //Current =Serial.read();
  //return Current;
void SendOperCommand(char Data1, char Data2)
  char CheckSum;
  CheckSum = (Data1^Data2)&0x7f;
  Serial.print(HEADER,BYTE);
  Serial.print(Data1,BYTE);
  Serial.print(Data2,BYTE);
  Serial.print(CheckSum,BYTE);
  int size = 1024;
  byte *buf;
  while ((buf = (byte *) malloc(--size)) == NULL);
  free(buf);
  return size;
No. You call Serial.read() occurs well before the motor has had a chance to response to the call to SendOperCommand. Why do you need to clear this buffer anyway? You don't appear to using RX serial anywhere.
115 thousand times per second = way too fast! :slight_smile:
You actually have 818 bytes free. The problem is that you are assigning the int return from availablememory() into a char variable.
Cheers,
Mikal
