Quick question, I am sure it is obvious for the officianardos. In the standard IDE, version 0022, how do I know if I am using too much ram, or if I am about to run out ? The compiler output tells you how much code is used and the avaialble size, I would assume the ram is as important. Is there a way to see the memory map ?
Thanks Tim
