Average.h library malfunction
Hey there,
Moderator edit: diatribe removed
(just saying i´m a complete beginnner so forgive me any mistakes i will try as hard as i can to fulfill forum regulation, etc.)
so my problem:
i donwloaded the "Average.h" library from Github and tried a GPS example for navigating a boat to specific waypoints (The Arduino IDE shows the library as installed so that´s not the problem).
When compiling the sketch to the Arduino Uno it shows the error: 'mean' was not declared in this scope
i have no idea what the problem is and i hope you can help me
thanks a lot,
Gus
Hello there!
Can you post the code you are using, as well as a picture of the error message(s) you are getting?
The sketch you didn't post?
The error message includes a lot more information than that.
bos1714:
Hello there!
DO NOT POST PICTURES OF TEXT.
If you want a simple moving average (i.e. Finite Impulse Respones), take a look at the RunningAverage example on the playground.
If you want an exponential moving average (which is better in many cases), you can use this:
[color=#95a5a6]/*[/color]
[color=#95a5a6]   Exponential Moving Average filter (single-pole IIR filter)[/color]
[color=#95a5a6]   Difference equation:[/color]
[color=#95a5a6]       y[n] = k*x[n] + (1-k)*y[n-1][/color]
[color=#95a5a6]     where y[n] is the filtered output at time n,[/color]
[color=#95a5a6]     and x[n] the raw input at time n[/color]
[color=#95a5a6]     y[n-1] is the previous filtered output.[/color]
[color=#95a5a6]   k == 0.5^shiftFac[/color]
[color=#95a5a6]   Fixed point arithmetic is used for speed.[/color]
[color=#95a5a6]     1 == 1 << (2*shiftFac)[/color]
[color=#95a5a6]   Two times shiftFac because otherwise, precision[/color]
[color=#95a5a6]   would be lost when shifting (value - filtered).[/color]
[color=#95a5a6]   Rounding is performed by adding 0.5 to the[/color]
[color=#95a5a6]   fixed point representation before converting[/color]
[color=#95a5a6]   to an integer.[/color]
[color=#95a5a6]     0.5 == 1 << (2*shiftFac - 1)[/color]
[color=#95a5a6]*/[/color]
[color=#00979c]class[/color] [color=#000000]EMA[/color] [color=#000000]{[/color]
  [color=#00979c]public[/color][color=#434f54]:[/color]
    [color=#95a5a6]/* Constructor: Initialize constants */[/color]
    [color=#000000]EMA[/color][color=#000000]([/color][color=#00979c]uint8_t[/color] [color=#000000]shiftFac[/color][color=#000000])[/color]
      [color=#434f54]:[/color] [color=#000000]shiftFac[/color][color=#000000]([/color][color=#000000]shiftFac[/color][color=#000000])[/color][color=#434f54],[/color] [color=#000000]fixedPointAHalf[/color][color=#000000]([/color][color=#000000]1[/color] [color=#434f54]<<[/color] [color=#000000]([/color][color=#000000]([/color][color=#000000]shiftFac[/color] [color=#434f54]*[/color] [color=#000000]2[/color][color=#000000])[/color] [color=#434f54]-[/color] [color=#000000]1[/color][color=#000000])[/color][color=#000000])[/color] [color=#000000]{[/color][color=#000000]}[/color]
    [color=#95a5a6]/* Filter a new raw input value x[n] and return the filtered output y[n].[/color]
[color=#95a5a6]       Should be called at regular intervals for best results. */[/color]
    [color=#00979c]int32_t[/color] [color=#d35400]filter[/color][color=#000000]([/color][color=#00979c]int32_t[/color] [color=#000000]value[/color][color=#000000])[/color] [color=#000000]{[/color]
      [color=#000000]value[/color] [color=#434f54]=[/color] [color=#000000]value[/color] [color=#434f54]<<[/color] [color=#000000]([/color][color=#000000]shiftFac[/color] [color=#434f54]*[/color] [color=#000000]2[/color][color=#000000])[/color][color=#000000];[/color]
      [color=#000000]filtered[/color] [color=#434f54]=[/color] [color=#000000]filtered[/color] [color=#434f54]+[/color] [color=#000000]([/color][color=#000000]([/color][color=#000000]value[/color] [color=#434f54]-[/color] [color=#000000]filtered[/color][color=#000000])[/color] [color=#434f54]>>[/color] [color=#000000]shiftFac[/color][color=#000000])[/color][color=#000000];[/color]
      [color=#5e6d03]return[/color] [color=#000000]([/color][color=#000000]filtered[/color] [color=#434f54]+[/color] [color=#000000]fixedPointAHalf[/color][color=#000000])[/color] [color=#434f54]>>[/color] [color=#000000]([/color][color=#000000]shiftFac[/color] [color=#434f54]*[/color] [color=#000000]2[/color][color=#000000])[/color][color=#000000];[/color]
  [color=#00979c]private[/color][color=#434f54]:[/color]
    [color=#95a5a6]/* Member variables */[/color]
    [color=#00979c]const[/color] [color=#00979c]uint8_t[/color] [color=#000000]shiftFac[/color][color=#000000];[/color]
    [color=#00979c]const[/color] [color=#00979c]int32_t[/color] [color=#000000]fixedPointAHalf[/color][color=#000000];[/color]
    [color=#00979c]int32_t[/color] [color=#000000]filtered[/color] [color=#434f54]=[/color] [color=#000000]0[/color][color=#000000];[/color]
[color=#000000]}[/color][color=#000000];[/color]
[color=#000000]EMA[/color] [color=#000000]ema[/color][color=#000000]([/color][color=#000000]4[/color][color=#000000])[/color][color=#000000];[/color] [color=#434f54]// k = 0.5^4 = 0.0625[/color]
[color=#00979c]const[/color] [color=#00979c]unsigned[/color] [color=#00979c]long[/color] [color=#d35400]interval[/color] [color=#434f54]=[/color] [color=#000000]10000[/color][color=#000000];[/color] [color=#434f54]// sample every 10 milliseconds[/color]
[color=#00979c]void[/color] [color=#000000]measureAndFilter[/color][color=#000000]([/color][color=#000000])[/color] [color=#000000]{[/color]
  [color=#00979c]int[/color] [color=#000000]x[/color] [color=#434f54]=[/color] [color=#d35400]analogRead[/color][color=#000000]([/color][color=#000000]A0[/color][color=#000000])[/color][color=#000000];[/color]
  [color=#00979c]int[/color] [color=#000000]y[/color] [color=#434f54]=[/color] [color=#000000]ema[/color][color=#434f54].[/color][color=#d35400]filter[/color][color=#000000]([/color][color=#000000]x[/color][color=#000000])[/color][color=#000000];[/color]
  [b][color=#d35400]Serial[/color][/b][color=#434f54].[/color][color=#d35400]println[/color][color=#000000]([/color][color=#000000]y[/color][color=#000000])[/color][color=#000000];[/color]
[color=#00979c]void[/color] [color=#5e6d03]setup[/color][color=#000000]([/color][color=#000000])[/color] [color=#000000]{[/color]
  [b][color=#d35400]Serial[/color][/b][color=#434f54].[/color][color=#d35400]begin[/color][color=#000000]([/color][color=#000000]115200[/color][color=#000000])[/color][color=#000000];[/color]
[color=#00979c]void[/color] [color=#5e6d03]loop[/color][color=#000000]([/color][color=#000000])[/color] [color=#000000]{[/color]
  [color=#00979c]static[/color] [color=#00979c]unsigned[/color] [color=#00979c]long[/color] [color=#000000]previousMicros[/color] [color=#434f54]=[/color] [color=#d35400]micros[/color][color=#000000]([/color][color=#000000])[/color][color=#000000];[/color]
  [color=#5e6d03]if[/color] [color=#000000]([/color][color=#d35400]micros[/color][color=#000000]([/color][color=#000000])[/color] [color=#434f54]-[/color] [color=#000000]previousMicros[/color] [color=#434f54]>[/color] [color=#d35400]interval[/color][color=#000000])[/color] [color=#000000]{[/color] [color=#434f54]// sample at precise interval[/color]
    [color=#000000]measureAndFilter[/color][color=#000000]([/color][color=#000000])[/color][color=#000000];[/color]
    [color=#000000]previousMicros[/color] [color=#434f54]+=[/color] [color=#d35400]interval[/color][color=#000000];[/color]
If you want help with the library you’re currently using, you’ll have to post all of your code and error messages, as well as a link to the library in question.
Pieter
oh wow thanks a lot!
i didnt expect that much response so fast.
so the library i used was this one: GitHub - MajenkoLibraries/Average: Templated class for calculating averages and statistics of data sets.
my code:
#include <Average.h>
#include <SoftwareSerial.h>
#include <PWMServo.h>
#include <Wire.h>
#include <HMC5883L.h>
#include "TinyGPS++.h"
int compassavg = 50;
PWMServo rudder;
int maxspeed = 40;
int waypointdist = 8;
int prevangle = 90;
int accuracy = 4;
int rudderspeed = 10;
int lock = 12;
int distance = 7;
int data = 5;
int gpsavg = 10;
int ruddertrim = -2;
int compasstrim = 180;
int ang = 0;
static int r = 6371;
const float Pi = 3.14159;
HMC5883L compass;
int error = 0;
TinyGPSPlus gps;
unsigned long startTime;
unsigned long otherTime;
SoftwareSerial ss(5, 4);
  Serial.begin(4800);
  rudder.attach(9);
  Wire.begin();
  compass = HMC5883L();
  error = compass.SetScale(0.88);
  error = compass.SetMeasurementMode(Measurement_Continuous);
  ss.begin(9600);
  startTime = millis();
  float bearing = RealBearing(49,-123,GetBearing());
  int heading = 0;
  RudderTurn(RudderAngle(bearing,heading));
  Serial.println(millis() - startTime);
  delay(200);
static void KeepHeading(int heading) {
  delay(200);
static void GoByPath(float lat2, float long2){
  gps.encode(ss.read());
  while (1 > 0){
    if (millis() > 5000 && gps.charsProcessed() < 10)
      digitalWrite(data, HIGH);
    else {
      digitalWrite(data, LOW);
    while (ss.available() > 0){
      if (gps.location.isUpdated())
pathagain:
        if (gps.speed.mps() > maxspeed){
          delay(100);
          goto pathagain;
        int latslice = gpsavg;
        int lati;
        float lataverage[latslice];
        for (lati = 0; lati < latslice; lati = lati + 1) {
          lataverage[lati] = gps.location.lat();
        float lat1 = mean(lataverage, latslice);
        int longslice = gpsavg;
        int longi;
        float longaverage[longslice];
        for (longi = 0; longi < longslice; longi = longi + 1) {
          longaverage[longi] = gps.location.lng();
        float long1 = mean(longaverage, longslice);
        float heading = GetHeading(lat1, long1, lat2, long2);
        while (1 > 0){
          if (GetDistanceInM(lat1, long1, lat2, long2) > accuracy){
            long1=GetPosition(lat1, long1, waypointdist, heading, 2);
            lat1=GetPosition(lat1, long1, waypointdist, heading, 1);
            GoToWaypoint(lat1, long1);
          else {
            return;
static void GoToWaypoint(float lat2, float long2){
  while (1 > 0){
        digitalWrite(lock, HIGH);
        float lat1, long1;
        lat1 = gps.location.lat();
        long1 = gps.location.lng();
        if (GetDistanceInM(lat1, long1, lat2, long2) < (accuracy/1.9)){
          ////Serial.println("Path Point Reached");
          digitalWrite(distance, HIGH);
          digitalWrite(distance, LOW);
          return;
        else {
gpsagain:
          int lati;
          int longi;
          if (gps.speed.knots() > maxspeed){
            delay(100);
            goto gpsagain;
          delay(20);
          int slice = 20;
          int i;
          int average[slice];
          for (i = 0; i < slice; i = i + 1) {
            average[i] = (int)GetBearing();
          float bearing = mode(average, slice);
          bearing = RealBearing(lat1, long1, bearing);
          RudderTurn(RudderAngle(bearing, heading));
      digitalWrite(lock, LOW);
  return;
static void RudderTurn(int angle){
  otherTime = millis();
  while (angle > prevangle) {
    prevangle++;
    rudder.write(prevangle);
    delay(rudderspeed);
  while (angle < prevangle) {
    prevangle--;
    delay(rudderspeed);
  otherTime = millis() - otherTime;
  if (otherTime < 800) {
    delay(800 - otherTime);
  prevangle = angle;
static float GetPosition(float lat1, float long1, float distance, float heading, int option)
  distance = distance / 1000;
  lat1 = ConvertToRadians(lat1);
  long1 = ConvertToRadians(long1);
  heading = ConvertToRadians(heading);
  float lat2 = asin(sin(lat1) * cos(distance / r) +
    cos(lat1) * sin(distance / r) * cos(heading));
  float long2 = long1 + atan2(sin(heading) * sin(distance / r) * cos(lat1),
  cos(distance / r) - sin(lat1) * sin(lat2));
  if (option == 1)
    return ConvertToDegrees(lat2);
    return ConvertToDegrees(long2);
static int RudderAngle(float bearing, float heading){
  heading = (int)heading % 360;
  bearing = (int)bearing % 360;
  if (heading == bearing)
    return 90;
  int o1 = (int)heading - (int)bearing;
  int o2 = (int)bearing - (int)heading;
  int dir = ((360-((int)heading - (int)bearing)) % 360);
  if (dir < 180) {
    if (dir > 30)
      return 60;
      return 90 - dir / 2;
  else if (dir >= 180)
    if ((360 - dir) > 30)
      return 120;
      return 90 + (360 - dir) / 2;
  return 90;
static float GetBearing(){
  int i;
  int average[compassavg];
  for (i = 0; i < compassavg; i = i + 1) {
    MagnetometerRaw raw = compass.ReadRawAxis();
    MagnetometerScaled scaled = compass.ReadScaledAxis();
    int MilliGauss_OnThe_XAxis = scaled.XAxis;// (or YAxis, or ZAxis)
    float heading = atan2(scaled.YAxis, scaled.XAxis);
    if(heading < 0)
      heading += 2*Pi;
    if(heading > 2*Pi)
      heading -= 2*Pi;
    float headingDegrees = (heading * 180/M_PI);
    headingDegrees = fmod((headingDegrees + compasstrim),360);
    average[i] = (int)headingDegrees;
  return mode(average, compassavg);
static float RealBearing(float lat1, float long1, float bearing)
  float magdif = GetHeading(lat1, long1, 75.7667, -99.7833);
  return (fmod((bearing + magdif),360));
static float GetHeading(float lat1, float long1, float lat2, float long2)
  lat2 = ConvertToRadians(lat2);
  long2 = ConvertToRadians(long2);
  float dLon = long2 - long1;
  float y = sin(dLon) * cos(lat2);
  float x = cos(lat1) * sin(lat2) - sin(lat1) * cos(lat2) * cos(dLon);
  return ConvertToStaticDegrees(atan2(y, x));
static float GetDistanceInM(float lat1, float long1, float lat2, float long2)
  float dLat = lat2 - lat1;
  float a = haversin(dLat) + cos(lat1) * cos(lat2) * haversin(dLon);
  float c = 2 * atan2(sqrt(a), sqrt(1 - a));
  return r * c * 1000; // Distance in M
static float ConvertToDegrees(float rad)
  float degrees = rad / (Pi / 180);
  if (degrees <= -180) {
    return degrees + 360;
  else {
    return degrees;
static float ConvertToStaticDegrees(float rad)
  if (degrees <= 0) {
  else {
    return degrees;
static float ConvertToRadians(float angle)
  return (Pi / 180) * angle;
static float haversin(float input)
  return (sin(input / 2)) * (sin(input / 2));
static void RoutineDone(){
  RudderTurn(0);
  delay(100);
  RudderTurn(180);
  delay(100);
and finally the error message (too many characters for one post):
C:\Users\augus\AppData\Local\Temp\Rar$DIa4312.33111\V02\V02.ino: In function 'void GoByPath(float, float)':
V02:95: error: 'mean' was not declared in this scope
C:\Users\augus\AppData\Local\Temp\Rar$DIa4312.33111\V02\V02.ino: In function 'void GoToWaypoint(float, float)':
V02:149: error: 'mean' was not declared in this scope
V02:171: error: 'mode' was not declared in this scope
C:\Users\augus\AppData\Local\Temp\Rar$DIa4312.33111\V02\V02.ino: In function 'float GetBearing()':
V02:272: error: 'mode' was not declared in this scope
A lot of librarys were found for "HMC5883L.h"
Used: C:\Users\augus\Documents\Arduino\libraries\HMC5883L
Not used: C:\Users\augus\Documents\Arduino\libraries\Grove_3-Axis_Digital_Compass_HMC5883L
exit status 1
First of all, refactor your code to get rid of the goto's.
Secondly, the compiler is right: 'mean' is not a free function, it's an instance function/method of the Average class, so it can only be invoked against an instance of that class.
Try studying the examples that come with the library.
ok i will do that
but somehow this one guy on instructables used exactly this code and this library and for him it worked
could this be a problem with my computer and its compatibility with the library?
Instructables are crap. No serious programmer, or hobbyist, would ever use code from an instructables.
GusWT:
Then he either defined that function somewhere else, or he used a different Average.h library.
@GusWT, any personal attack is unacceptable. Even ones directed at anonymous groups. Do not do it again.
@PaulS, stop picking on the cuss redacted ... uh ... newbies.
short explaining needed! i have literally no idea what you are talking about
GusWT:
Asshole. You post that word again you are banned.
