jun325
April 16, 2021, 11:59am
1
Hi guys.. hope you can help me this one.. Since the reading of my load cell fluctuates due to the vibration and other factors, I need to find its average. By the way i use a millligrams unit.
#include "HX711.h"
// HX711 circuit wiring
const int DF_DOUT = 2; // DOUT for drag
const int DF_SCK = 4; // SCK for Drag
const int LF_DOUT = 11; // DOUT for Lift
const int LF_SCK = 12; // SCK for Lift
//HX711 constructor:
HX711 DFORCE;
HX711 LFORCE;
Serial.begin(38400);
Serial.println("Starting Set Up...");
DFORCE.begin(DF_DOUT, DF_SCK);
DFORCE.set_scale();
DFORCE.tare();
LFORCE.begin(LF_DOUT, LF_SCK);
LFORCE.set_scale();
LFORCE.tare();
long DragOrigRead = DFORCE.read ();
long Drag2ndRead;
long Drag1stRead;
long LiftOrigRead = LFORCE.read ();
long Lift2ndRead;
long Lift1stRead;
Serial.println("Start The Fan And Set A Desired Velocity");
Drag1stRead = (-000.524* LiftOrigRead) -127008.2+14000;
Lift1stRead = (-000.525* DragOrigRead) +37008.2+52000;
Serial.print("Drag Force Reading Is:");
Serial.print(Drag1stRead);
Serial.print("Lift Force Reading Is:");
Serial.print(Lift1stRead);
delay(10000);
So, sum a number of readings, and divide the sum by the number of readings.
If you need a moving average, there are libraries for that, or you can write a simple circular buffer, so you subtract the oldest reading and add the newest to a running total.
jun325
April 16, 2021, 12:32pm
3
thank you for the response sir..by the way hows my code gonna look like??..can you show me sir?
gcjr
April 16, 2021, 12:34pm
4
you can also try leaky integration
avg += (reading - avg) * K; // K < 1
jun325
April 16, 2021, 12:36pm
5
hows gonna my code look like?
You need to decide how you want your software to perform.
jun325
April 16, 2021, 12:52pm
7
how and where to insert that line to my code?
Your code can be structured like this, using an enum statement and converting all your code into separated functions:
#include "HX711.h"
// Declare functions
enum MeasurementType {drag, lift};
long takeMeasurement(MeasurementType type);
long getAverage(MeasurementType type, int N_Measurement);
HX711 DFORCE;
HX711 LFORCE;
Serial.println("Starting Set Up…");
DFORCE.set_scale();
DFORCE.tare();
LFORCE.set_scale();
LFORCE.tare();
long DragRead = getAverage(DFORCE, drag, 5); // Get the drag average of 5 measurements
long LiftRead = getAverage(LFORCE, lift, 5); // Get the lift average of 5 measurements
Serial.print(DragRead);
Serial.print(LiftRead);
// THE CODE YOU WANT HERE
delay(10000);
long takeMeasurement(HX711 FORCE, MeasurementType type) {
long measurement = 0;
switch (type) {
case drag:
measurement = (-000.524 * FORCE.read ()) - 127008.2 + 14000;
case lift:
measurement = (-000.525 * FORCE.read ()) + 37008.2 + 52000;
return measurement;
long getAverage(HX711 FORCE, MeasurementType type, int N_Measurements) {
long average = 0;
for (int i = 0; i < N_Measurements; i++) {
average += takeMeasurement(FORCE, type) / N_Measurements;
return average;
I hope this help you in your project.
Cheers!
jun325
April 16, 2021, 1:50pm
9
thank you very much for your help sir.God Bless:heart:
I'd be inclined to use references for the sensor objects in the functions, then you wouldn't need the enums
system
Closed
August 14, 2021, 3:51pm
11
