averaging analog input readings??
I am going to use a homemade soil moisture sensor to control my lawn sprinklers. currently I am experimenting an i made sensors from plaster of paris. I realize the downfalls of such sensors and may modify my plans but for right now I have a question.
My sensor readings are a bit erratic at times. I have my arduino at my desk and about 25 feet away and outside my window is my sensor plugged into the soil of my yard.
my readings are fluctuating a bit.
I was wondering. Is there a line of code that would take the average of the last say 10 sensor readings and return that value instead so to smooth the readings?
thanks for your help.
2 ways:
partial code, need to be completed.
  int readings = 10;
  int raw = 0;
  for int i = 0; i< readings; i++) raw += analogRead(A0);
  raw /= readings;
  serial.println(raw);
long raw = 0;
  raw =  (90* raw + 10 * analogRead(A0)) / 100;  // new reading can change 10% of the value
Note that the second needs some time to stabilize ==> you can do a first reading in setup() of course…
Not a line of code, but it isn’t hard. Use a for loop to take 10 readings, with a suitable delay in between. Sum those readings, and divide by the number of readings.
const int numReads = 10;
   int averageReading = 0;
   for(int i=0; i<numReads; i++)
      averageReading += analogRead(pin);
      delay(10000);
   averageReading /= numReads;
thanks sooo much for your help. this is my code I am using... do I just add yours after mine? sorry, newbie.
// SENSOR READING
int sensePin =0;
int ledPin = 9;
 analogReference (DEFAULT); //isnt nec
 Serial.begin (9600);
void loop(){
  Serial.println (analogRead(sensePin));
  delay (3000);
Add mine before your print statement. Then change the print statement to print averageReading, instead.
thanks allot!!! :)
did it but its not working… what did I mess up?
its giving an error of:
expected constructor,destructor, or type conversion before ‘.’ token
for line
Serial.println (averageReading (sensePin));
// SENSOR READING
int sensePin =0;
      averageReading += analogRead(sensePin);
      delay(10000);
  delay (3000);
Look at the extent of the loop function. You have code outside of the function.
I think you meant... move the } thing below the line.
now it says 'averageReading' was not declared in this scope
The variable averageReading is not a function. Don't try to use it like one.
Its possible to do what usually termed a running average (but is more technically a simple "infinite-impulse-response digital filter") like this:
  float averageReading = 0.0 ;
  averageReading += 0.1 * (analogRead (sensePin) - averageReading) ;
  delay (3000);
  Serial.println (averageReading) ;
The magic value 0.1 determines how slowly the filter responds to input changes - smaller means more slowly. So 0.3 will be quite quick, 0.01 will average over hundreds of readings. Set it to 1.0 and there is no averaging at all.
thanks guys
