My energy monitoring project is complete but I'd like to improve it. Even though I was helped by generous forum members with the parts, printed values still aren't accurate and stable. To correct this I was suggested to average them.
Here is the printing sequence from the .cpp file of the Emon library:
The entire code is pretty large. Here's the 1st half:
Emon.cpp - Library for openenergymonitor
Created by Trystan Lea, April 27 2010
GNU GPL
modified to use up to 12 bits ADC resolution (ex. Arduino Due)
by boredman@boredomprojects.net 26.12.2013
Low Pass filter for offset removal replaces HP filter 1/1/2015 - RW
//#include "WProgram.h" un-comment for use on older versions of Arduino IDE
#include "EmonLib.h"
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#endif
// Sets the pins to be used for voltage and current sensors
void EnergyMonitor::voltage(unsigned int _inPinV, double _VCAL, double _PHASECAL)
inPinV = _inPinV;
VCAL = _VCAL;
PHASECAL = _PHASECAL;
offsetV = ADC_COUNTS>>1;
void EnergyMonitor::current(unsigned int _inPinI, double _ICAL)
inPinI = _inPinI;
ICAL = _ICAL;
offsetI = ADC_COUNTS>>1;
// Sets the pins to be used for voltage and current sensors based on emontx pin map
void EnergyMonitor::voltageTX(double _VCAL, double _PHASECAL)
inPinV = 2;
VCAL = _VCAL;
void EnergyMonitor::currentTX(unsigned int _channel, double _ICAL)
if (_channel == 1) inPinI = 3;
if (_channel == 2) inPinI = 0;
if (_channel == 3) inPinI = 1;
ICAL = _ICAL;
// emon_calc procedure
// Calculates realPower,apparentPower,powerFactor,Vrms,Irms,kWh increment
// From a sample window of the mains AC voltage and current.
// The Sample window length is defined by the number of half wavelengths or crossings we choose to measure.
void EnergyMonitor::calcVI(unsigned int crossings, unsigned int timeout)
#if defined emonTxV3
int SupplyVoltage=3300;
#else
int SupplyVoltage = readVcc();
#endif
unsigned int crossCount = 0; //Used to measure number of times threshold is crossed.
unsigned int numberOfSamples = 0; //This is now incremented
// 1) Waits for the waveform to be close to 'zero' (mid-scale adc) part in sin curve.
boolean st=false; //an indicator to exit the while loop
unsigned long start = millis(); //millis()-start makes sure it doesnt get stuck in the loop if there is an error.
while(st==false) //the while loop...
startV = analogRead(inPinV); //using the voltage waveform
if ((startV < (ADC_COUNTS*0.55)) && (startV > (ADC_COUNTS*0.45))) st=true; //check its within range
if ((millis()-start)>timeout) st = true;
// 2) Main measurement loop
start = millis();
while ((crossCount < crossings) && ((millis()-start)<timeout))
numberOfSamples++; //Count number of times looped.
lastFilteredV = filteredV; //Used for delay/phase compensation
// A) Read in raw voltage and current samples
sampleV = analogRead(inPinV); //Read in raw voltage signal
sampleI = analogRead(inPinI); //Read in raw current signal
// B) Apply digital low pass filters to extract the 2.5 V or 1.65 V dc offset,
// then subtract this - signal is now centred on 0 counts.
offsetV = offsetV + ((sampleV-offsetV)/1024);
filteredV = sampleV - offsetV;
offsetI = offsetI + ((sampleI-offsetI)/1024);
filteredI = sampleI - offsetI;
// C) Root-mean-square method voltage
sqV= filteredV * filteredV; //1) square voltage values
sumV += sqV; //2) sum
// D) Root-mean-square method current
sqI = filteredI * filteredI; //1) square current values
sumI += sqI; //2) sum
long previousMillis;
long currentMillis;
long interval=100;
float total=0;
int counter=0;
float adjusted_sample;
float sample=70;
currentMillis = millis();
if(currentMillis - previousMillis > interval) {
total = total + sample;
counter++;
if (counter==10) {
adjusted_sample = (total/10);
total=0;
counter=0;}
previousMillis = currentMillis;}
Serial.print(sample);
Serial.print (" ");
Serial.print (total);
Serial.print (" ");
Serial.println (adjusted_sample);
just a old piece of code of I was playing with while messing with a temp sensor......down side of this is that it will not work if you have delays in the program as it requires the loop to be read every 10th of a second. (thinking about that it shouldn't matter other than the reading will not be updated every second)
Delta_G:
And take your readings and add them up as you go. When you've got ten readings added up, divide by 10 and you've got your average value. What part of that is complicated?
I don't know how the program detects 10 readings, how it knows when to sum up and print the average.
gpop1:
long currentMillis;
long interval=100;
float total=0;
int counter=0;
float sample=70;
counter++;
if (counter==10) {
total=0;
counter=0;}
Thanks, gpop1. As soon as I get a chance I'll update it.
