I am interested in averaging a bunch of values together for a smoothing technique. I'm thinking a for loop? I know there is code out there already, however I am in part trying to write some custom code and also TRYING TO LEARN how FOR loops work (in their many iterations).
Anyway, specifically I'd like to do something like this:
//gather and add all these values together
if (value>0) {add all these values together}
//find how many values from above there are to make an average
if (value sensor value was taken then +1 until (for each time)
//get the average
(all values added together) + number of sensor values (step 2 from above)
//If sensor value is zero (or negative number territory) than start fresh with new average
(start over again)
The other part I'm not sure about is when it knows to check the sensor value. What if I want 10 samples....or 80 samples etc? Possibly we would need to implement a millis timer to know when to sample?
Thank you in advance. Again, I'm really trying to learn how this works so spelling it in noob level English would be greatly appreciated.
- //get the average
Correction: 3. //get the average
(all values added together) ÷ number of sensor values (step 2 from above)
If you want to spread the sampling over a period of time then don't use a for loop. A for loop, by its nature, locks you into it until all of its iterations have occurred. Actually, you can exit from it early but you can't then go back to where you left off.
Let the loop() function do what its name implies and use millis() for timing
Something like this maybe
averaging = false
doneMeasuring = false
counter = 0
total = 0
start of loop()
code here to set averaging to true to start measurements when required
if averaging equals true
if wait between measurements has passed // use millis() for timing
take a measurement
add measurement to the total
increment counter
if all measurments taken
set averaging to false to prevent more being taken
set doneMeasuring to true to trigger calculation
end if
end if
if doneMeasuring is true
divide total by counter to get average of measurements
set doneMeasuring to false to prevent more calculations until required
end if
end of loop
Woops...yes divide by... thanks.
Ok that explaination makes sense to me. I will try coding it tonight and try to implement on real system on Monday. Thanks UK
You cold look into the code of TPinInput from the TDuino library, which can bot calculate a buffered average or a non-buffered average - bot non-blocking
UsernameD:
I suggest that you start with a small number of data points read from an array of values. That way you have control over what goes in and can determine whether the calculated average is what you expect it to be.
