I am very new to arduino programming and sorry for my bad english. I wrote a code to count up and down. I can limit count up as i need but i cant control countdown. It come negetive numbers
This is my code :-
State change detection (edge detection)
Often, you don't need to know the state of a
digital input all the time, but you just need
to know when the input changes from one state to
another. For example, you want to know when a
button goes from OFF to ON. This is called
state change detection, or edge detection.
This example shows how to detect when a button
or button changes from off to on and on to off.
The circuit:
- pushbutton attached to pin 2 from +5V
- 10K resistor attached to pin 2 from ground
- LED attached from pin 13 to ground (or use the
built-in LED on most Arduino boards)
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/ButtonStateChange
int buttonState = 0;
int lastButtonState = 0;
int buttonPushCounter = 0;
int bS = 0;
int lBS = 0;
int bPC = 0;
pinMode(2, INPUT);
pinMode(4, INPUT);
// read the pushbutton input pin
buttonState = digitalRead(2);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH) {
// if the current state is HIGH, then the button
// went from off to on
buttonPushCounter += 1;
Serial.println("on");
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter);
// if the current state is LOW, then the button
// went from on to off
Serial.println("off");
// delay a little bit to avoid debouncing
delay(5); // Wait for 5 millisecond(s)
// save the current state as the last state, for
// the next time through the loop
lastButtonState = buttonState;
if (buttonPushCounter == 10){
bS = digitalRead(4);
if (bS != lBS) {
if (bS == HIGH) {
buttonPushCounter -= 1;
lBS = bS;
Plz help me
