I have a relay to control the backlight of the lcd using a relay.
// Turn on LCD backlight when motion detected at night and day.
digitalWrite(RELAY2, (photoresistorValue >= 700) || pir_sensor_value);
but sometimes
photoresistorValue
is closely shuffling near ± 700 ,
so I want to know a way that of a condition is set to true it should not immidiately turn of relay but wait for a while instead to meet the new condition .
int RELAY2 = D4;
int RELAY3 = D5;
int RELAY4 = D6;
int photoresistor = A0;
int pir_sensor_value = 0;
int photoresistorValue = 0;
#define PIR_SENSOR_PIN D7
int backlightState = HIGH ;
int reading = LOW;
int relay2State;
int lastRelay2State = LOW;
unsigned long lastDebounceTime = 0; // the last time the output
unsigned long debounceDelay = 50; // the debounce time; increase of the output flickers.
//Initilize the relay control pins as output
pinMode(RELAY2, OUTPUT);
pinMode(RELAY3, OUTPUT); // D5
pinMode(RELAY4, OUTPUT);
pinMode(photoresistor, INPUT);
pinMode(PIR_SENSOR_PIN, INPUT);
void loop (){
if (photoresistorValue >= 700 || pir_sensor_value){
reading = HIGH;
else {
reading = LOW;
if (reading != lastRelay2State) {
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer than the debounce
// delay, so take it as the actual current state:
// if the button state has changed:
if (reading != relay2State) {
relay2State = reading;
// only toggle the LED if the new button state is HIGH
if (relay2State == HIGH) {
backlightState = !backlightState;
// Set the backlight of lcd
digitalWrite(RELAY2, backlightState);
