I am using Arduino IDE 1.8.19 on a Rpi 4 with Linux Bookworm 64-bit.
I am using an Arduino Nano burned to look like an Arduino UNO ( as per NIck Gammon's instructions) as an ISP - "Arduino as ISP".
I have added this board so that I can program an ATTiny85:
https://raw.githubusercontent.com/damellis/attiny/ide-1.6.x-boards-manager/package_damellis_attiny_index.json
This process has worked OK in the past though with earlier levels of software but I wanted to change the ATTiny85 clock speed from 16MHz to 8Mhz.
The compile process has worked fine as far as I can tell - error free.
However, when I come to use the "Burn Bootloader" function it fails with these messages:
REMOVE/bin/avrdude -C/etc/avrdude.conf -v -v -v -v -pattiny85 -cstk500v1 -P/dev/ttyUSB0 -b19200 -e -Uefuse:w:0xff:m -Uhfuse:w:0xdf:m -Ulfuse:w:0xe2:m
java.io.IOException: Cannot run program "REMOVE/bin/avrdude": error=2, No such file or directory
at java.base/java.lang.ProcessBuilder.start(ProcessBuilder.java:1143)
at java.base/java.lang.ProcessBuilder.start(ProcessBuilder.java:1073)
at java.base/java.lang.Runtime.exec(Runtime.java:594)
at java.base/java.lang.Runtime.exec(Runtime.java:453)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:11)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:129)
at cc.arduino.packages.uploaders.SerialUploader.runCommand(SerialUploader.java:383)
at cc.arduino.packages.uploaders.SerialUploader.burnBootloader(SerialUploader.java:372)
at processing.app.Editor.lambda$handleBurnBootloader$61(Editor.java:2385)
at java.base/java.lang.Thread.run(Thread.java:840)
Caused by: java.io.IOException: error=2, No such file or directory
at java.base/java.lang.ProcessImpl.forkAndExec(Native Method)
at java.base/java.lang.ProcessImpl.(ProcessImpl.java:314)
at java.base/java.lang.ProcessImpl.start(ProcessImpl.java:244)
at java.base/java.lang.ProcessBuilder.start(ProcessBuilder.java:1110)
... 9 more
I have tried the same process on a desktop PC with an AMD chip running Linux Mint 20 64-bit with the same versions of Arduino IDE and board levels and the "Burn Bootloader" process runs successfully.
I then reverted the AVR board on the Rpi to 1.8.5 from 1.8.6 and both processes completed successfully.
I conclude that something has changed in the 1.8.6 version of the AVR board but I have insufficient knowledge of how it works to determine the actual problem. From Google searches I understand the "REMOVE" means the IDE is unable to find AVRDUDE in the "Burn Bootloader" phase yet it uses "/usr/bin/avrdude" for the compile phase.
Can anyone advise on next step?
