An interesting graph over time that number would make.
It's 2021 and you probably could say 99.99%, and in these fora add some more 9s.
Although… now that we have reliable industrial strength compilers, perhaps the vindictive finger is pointed at them less often - most ppl know to blame the compiler down nearer the end or even off the end of the A, B, C &c. list of things to look at next.
Every piece of software has bugs. Although the next list seems outdated (maybe the bugs has been fixed since then) one can notice that the compiler is bug-free: AVR Toolchain Bugs
It's not a bug in my opinion, it's the way the compiler generates the code; it follows rules. It first does the shift and next it assigns; as the shift is done on the 16-bit variable, you will end up with 0. The way around could have been to first assign the 16-bit variable to the 32-bit variable and next shift the 32-bit variable.
I beg to differ, you describe the behaviour for non-volatile variables. Volatile variables are not kept in registers except for the evaluation of a single expression.
One way to see this - assuming you are confident of the problem - what is a practical course of action? Have you found the line(s) of code that are the definite cause? If you can't fix it, you have to:
Fix it yourself
Convince someone else to fix it.
So, how are you going to accomplish #2? If all the evidence you have is mysteriously buried deeply inside a proprietary program that also uses an RTOS, but you can't actually point to the cause, you are asking someone else (who is not hearing any complaints from anyone else) to dig through all that stuff for you. How many hours do you think that would take? Any renumeration? I didn't think so. So put yourself in their shoes. That is what an MRE does, takes the burden off the maintainer by isolating the problem.
And - this is an Arduino programming forum. Not an AVR-GCC code hub. You can complain here all week and all you would get is sympathy or the lack of it. To get action on something like this, you have to open a pull request or whatever the maintainers use to track bugs.
Also, compiler maintainers don't care about applications. They only try to guarantee that the language specification is adhered to.
How can somebody define shift behaviour different from the three machine instructions shl, shr and asr, leaving many undefined or implementation specific cases
Now at least I see no chance for a compiler bug. Case closed?
Any strongly typed language should barf if you ask it to shift a signed quantity. Just because the processor can do it, doesn't mean it makes any sense.
This would require introducing an alternate "arithmetic shift operator" in C. The lack of it, might be a valid point. But they had to draw the line on features somewhere. C was supposed to be concise.
Not necessarily. Arithmetic shift could be selected with signed types, because it makes sense only there. The user then can switch between shr and asr by casting the operand. But such simple handling might break legacy code, so bad design decisions have to be preserved and detailed further forever
I think I understand, you propose that it be selected automatically, according to type. Hey, C/C++ isn't perfect. Someday there will be something much better.
