AVR problem
How to fix this, I have Elegoo Uno R3
This will help...
OP: Missing "void" ?
@Coding Badly: LOL!
Looks like the compiler doesn't like the ISR declaration. It could be that the function above that is not correctly formed.
Danois90:
That is certainly a good guess. And I appreciate your attempt to help.
But, the ISR macro includes the return type...
ISR(ADC_vect)
void setup( void )
void loop( void )
Sketch uses 464 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
Yep, figured that out. The problem is most likely located in the (super-secret un-posted) code above the ISR :slight_smile:
+1
Adventures in Babysitting - Babysitting Blues
"Nobody Leaves This Place Without Singing The Blues"
This is whole code my bad for sloppy question.
This is code, I just copy it form net
OScope
Oscilloscope based on arduino and Processing.
http://yaab-arduino.blogspot.it/p/oscope.html
#include <avr/interrupt.h>
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#define NUMSAMPLES 1024
#define INPUTPIN A0
byte buf[NUMSAMPLES];
int x=0;
unsigned long t, t0;
 // initialize the serial port to 230400 baud, if you have problems lower it to 115200
 Serial.begin(230400);
 ADCSRA = 0;             // clear ADCSRA register
 ADCSRB = 0;             // clear ADCSRB register
 ADMUX |= (0 & 0x07);    // set A0 analog input pin
 ADMUX |= (1 << REFS0);  // set reference voltage
 ADMUX |= (1 << ADLAR);  // left align ADC value to 8 bits from ADCH register
 // sampling rate is [ADC clock] / [prescaler] / [conversion clock cycles]
 // for Arduino Uno ADC clock is 16 MHz and a conversion takes 13 ADC clocks
 //ADCSRA |= (1 << ADPS2) | (1 << ADPS0);    // 32 prescaler for 38.5 KHz
 ADCSRA |= (1 << ADPS2);                     // 16 prescaler for 76.9 KHz
 //ADCSRA |= (1 << ADPS1) | (1 << ADPS0);    // 8 prescaler for 153.8 KHz
 ADCSRA |= (1 << ADATE); // enable auto trigger
 ADCSRA |= (1 << ADIE);  // enable interrupts when measurement complete
 ADCSRA |= (1 << ADEN);  // enable ADC
 ADCSRA |= (1 << ADSC);  // start ADC measurements
ISR(ADC_vect) { // store 8 bit value from input
 byte inVal = ADCH;
 if (x==0)
   t0 = micros();
 if (x>=NUMSAMPLES)
   return;
 buf[x] = inVal;
 x++;
 if (x==NUMSAMPLES)
   // send 255 to mark the beginning of buffer
   Serial.write(255);
   // send the length of the buffer
   Serial.write((byte) (NUMSAMPLES & 0xFF));
   Serial.write((byte) ((NUMSAMPLES >> 8) & 0xFF));
   // send elapsed time
   t = micros()-t0;
   Serial.write((byte) (t & 0xFF));
   Serial.write((byte) ((t >> 8) & 0xFF));
   Serial.write((byte) ((t >> 16) & 0xFF));
   Serial.write((byte) ((t >> 24) & 0xFF));
   for (int i=0; i<NUMSAMPLES; i++)
     // do not send 255 because is used to mark the start of the buffer
     Serial.write(min(buf[i], 254));
   x=0;
And the error is
OScope:45:5: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\tarik\Desktop\speedUp\OScope\OScope.ino: In function 'void setup()':
OScope:27:3: error: 'ADCSRA' was not declared in this scope
OScope:28:3: error: 'ADCSRB' was not declared in this scope
OScope:29:3: error: 'ADMUX' was not declared in this scope
OScope:30:18: error: 'REFS0' was not declared in this scope
OScope:31:18: error: 'ADLAR' was not declared in this scope
OScope:36:19: error: 'ADPS2' was not declared in this scope
OScope:39:19: error: 'ADATE' was not declared in this scope
OScope:40:19: error: 'ADIE' was not declared in this scope
OScope:41:19: error: 'ADEN' was not declared in this scope
OScope:42:19: error: 'ADSC' was not declared in this scope
C:\Users\tarik\Desktop\speedUp\OScope\OScope.ino: At global scope:
OScope:45:4: error: expected constructor, destructor, or type conversion before '(' token
exit status 1
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
Baksuz:
You might want to go back to where you copied it from and follow the instructions on how to compile/use it.
It compiles without error for me.
Arduino 1.8.7
I tried three different AVR processors:
Arduino/Genuino UNO
Arduino/Genuino Micro
Arduino/Genuino Mega 2560
What AVR board did you select in Tools->Boards?
Baksuz:
OScope
#define INPUTPIN A0
int x=0;
byte inVal = ADCH;
if (x==0)
  t0 = micros();
if (x>=NUMSAMPLES)
  return;
buf[x] = inVal;
x++;
if (x==NUMSAMPLES)
  Serial.write(255);
  t = micros()-t0;
  x=0;
And the error is
exit status 1
Moderator edit:
<mark>```</mark>
<mark>[code]</mark>
<mark>```</mark>
<mark>```</mark>
<mark>```</mark>
tags added.
What board do you have selected? There's a lot more errors in there than just the top one, and they absolutely should not be happening if you have a proper board selected.
