Hello there,
I am facing an error in my project, Health Monitoring System using Arduino Uno R3, where I basically interfaced a temperature and a heart beat sensor through Arduino Uno R3 on Proteus software. The sensor library and Arduino library for Proteus are downloaded from https://www.theengineeringprojects.com/. I compiled the code on Arduino IDE 1.8.13
Here is the code :
#include <LiquidCrystal.h>
#include <TimerOne.h>
LiquidCrystal lcd(13, 12, 11, 10, 9, 8);
int val;
int tempPin = A0;// temperature Sensor Pin
int HBSensor = 4;// Sensor Pin
int HBCount = 0;
int HBCheck = 0;
int TimeinSec = 0;
int HBperMin = 0;
int HBStart = 2;
int HBStartCheck = 0;
lcd.begin(20, 4);
pinMode(HBSensor, INPUT);
pinMode(HBStart, INPUT_PULLUP);
Timer1.initialize(800000);
Timer1.attachInterrupt( timerIsr );
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Current HB : ");
lcd.setCursor(0,1);
lcd.print("Time in Sec : ");
lcd.setCursor(0,2);
lcd.print("HB per Min : 0.0");
lcd.setCursor(0,3);
lcd.print("Body Temp : ");
if(digitalRead(HBStart) == LOW){
//lcd.setCursor(0,3);
//lcd.print("HB Counting ..");
HBStartCheck = 1;}
if(HBStartCheck == 1)
if((digitalRead(HBSensor) == HIGH) && (HBCheck == 0))
HBCount = HBCount + 1;
HBCheck = 1;
lcd.setCursor(14,0);
lcd.print(HBCount);
lcd.print(" ");
if((digitalRead(HBSensor) == LOW) && (HBCheck == 1))
HBCheck = 0;
if(TimeinSec == 10)
HBperMin = HBCount * 6;
HBStartCheck = 0;
lcd.setCursor(14,2);
lcd.print(HBperMin);
lcd.print(" ");
//lcd.print("Press Button again.");
HBCount = 0;
TimeinSec = 0;
val = analogRead(tempPin);
float mv = (val/1024.0)*5000;
float cel = mv/10;
lcd.setCursor(14,3);
lcd.print(cel);
lcd.print(" ");
delay(100);
void timerIsr()
TimeinSec = TimeinSec + 1;
lcd.setCursor(14,1);
lcd.print(TimeinSec);
lcd.print(" ");
Then I uploaded the exported HEX file on Arduino Uno R3 on Proteus and ran the circuit which displayed 2 fatal errors:
AVR: Program property is not defined.
Real Time Simulation failed to start.
I have tried every possible solution I could barely find and yet the issue persists. Any help would really be appreciated. Thank you!
(circuit schematic is attached below)
