since the last topic didnt gave me a clear answer i'd like to start a new one:
Since the beginning i bought the board it doesnt work. Every time i try to upload the led program i get this:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
Some info:
Arduino Diecimila (freeduino clone 00012)
Windows XP
No firewall or what so ever.
Com5, but the board is USB with FTDI USB Drivers.
When connected:
Pwr led always on
TX and RX blinks 3 times, then the "13" led blinks 3 tmes...then it stops
When trying to upload:
RX blinks blinks 3 times, then stops, then 3 times etc. until the error comes. TX and "13" blinks acfter Rx but only the first time then its off.
Pwr led is still on
When i hit the reset button:
nothing... (but i don't question my solder skills and its perfectly connected)
I tried the troubleshooting FAQ but it didnt help. I cant go back to the manfacturer cuz we bought it with 200 ppl together or so from some foreign country
Remove the AVR from the circuit.
Connect a wire between digital 1 and digital 0 (TX and RX)
connect to your computer via USB.
Run Arduino, and select the serial monitor.
Type stuff in the send window and see if it echos back when you send.
Report back. If this works, it shows that the FTDI chip and drivers are operating properly and the problem lies elsewhere.
thanks for help!
I shirted port 1 and 2 (tx and rx) together and when i type something i can see it appear on the program. I also tried hyperterminal and that works too
