avrdude: butterfly_recv(): programmer is not responding
Hello,
Thank you in advance for your help
I am using a computer with windows 10 and I have the Arduino IDE 1.6.7
I have been programming the Arduino yun without any trouble since yesterday when this message appeared every time I tried to upload any code.
Connecting to programmer: avrdude: butterfly_recv(): programmer is not responding
After trying multiple solutions I confirmed that:
  1. There is nothing related to the code wrong because the same error appears with a blink or empty sketch
  2. The board is presumably correct because the same error appears with other boards (Arduino Leonardo)
I have re-installed the Arduino IDE but the problem wasn't fixed. Furthermore, troubleshooting the Arduino yun from 'My Devices' I received a message that said that this device wasn't compatible because worked with USB 2.0 and my computer runs with USB 3.0; however, I found this pretty unlikely because I have worked with this Arduino and this computer many times before without any errors.
About 15,000,000 results
