Avrdude continues to give error message when uploading.
I am receiving the following message when trying to upload the Settlers of Catan dice to my Mega 2560 board. (Link mentioned) What am I doing wrong?
/private/var/folders/4d/bldd5w2j6_g726d11nmk3_4m0000gn/T/AppTranslocation/7B5819CE-E1AC-4824-A494-2201A23AB882/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/private/var/folders/4d/bldd5w2j6_g726d11nmk3_4m0000gn/T/AppTranslocation/7B5819CE-E1AC-4824-A494-2201A23AB882/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega2560 -cwiring -P/dev/cu.usbmodem141301 -b115200 -D -Uflash:w:/var/folders/4d/bldd5w2j6_g726d11nmk3_4m0000gn/T/arduino_build_338260/settlers_of_catan_dice_code.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/private/var/folders/4d/bldd5w2j6_g726d11nmk3_4m0000gn/T/AppTranslocation/7B5819CE-E1AC-4824-A494-2201A23AB882/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/jonathan/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem141301
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version Master : 2.10
Vtarget : 0.0 V
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: reading input file "/var/folders/4d/bldd5w2j6_g726d11nmk3_4m0000gn/T/arduino_build_338260/settlers_of_catan_dice_code.ino.hex"
avrdude: writing flash (3918 bytes):
Writing | ################################################## | 100% 0.66s
avrdude: 3918 bytes of flash written
avrdude: verifying flash memory against /var/folders/4d/bldd5w2j6_g726d11nmk3_4m0000gn/T/arduino_build_338260/settlers_of_catan_dice_code.ino.hex:
avrdude: load data flash data from input file /var/folders/4d/bldd5w2j6_g726d11nmk3_4m0000gn/T/arduino_build_338260/settlers_of_catan_dice_code.ino.hex:
avrdude: input file /var/folders/4d/bldd5w2j6_g726d11nmk3_4m0000gn/T/arduino_build_338260/settlers_of_catan_dice_code.ino.hex contains 3918 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.53s
avrdude: verifying ...
avrdude: 3918 bytes of flash verified
avrdude done. Thank you.
settlers_of_catan_dice_code.ino (1.02 KB)
Now it's working again. Thank you!
As I would expect, as that output indicates a successful upload...
