Avrdude error, can't upload sketch to board
Hi and thanks for tuning in.
I am trying to get a stepper motor to work for a lamp project (hint: it's not a discoball), and actually it was working as expected. I changed only some numbers in the code related to stepper speed. Now I get a long avrdude error message when outputted verbose. As far as I can tell the only thing that looks like a problem is
"User configuration file does not exist or is not a regular file, skipping"
I've been trying to find answers online and on this forum and found someone saying that this specific part of the error message can be regarded as normal and that it is safe to ignore it. This was in a post where the problem was the port couldn't be found, which doesn't seem to be the problem here, for as far as I can tell.
But other than that I cannot find any concrete problem indicators from this error message.
Here's the full version:
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/$$/.avrduderc"
         Using Port                    : /dev/cu.usbmodem14101
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
    Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
    Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: reading input file "/var/folders/3q/jzgynmln5ml0mv0gn6v0p3f40000gn/T/arduino_build_58877/MotorRotorTest1.ino.hex"
avrdude: writing flash (4326 bytes):
Writing | ################################################## | 100% 0.32s
avrdude: 4326 bytes of flash written
avrdude: verifying flash memory against /var/folders/3q/jzgynmln5ml0mv0gn6v0p3f40000gn/T/arduino_build_58877/MotorRotorTest1.ino.hex:
avrdude: load data flash data from input file /var/folders/3q/jzgynmln5ml0mv0gn6v0p3f40000gn/T/arduino_build_58877/MotorRotorTest1.ino.hex:
avrdude: input file /var/folders/3q/jzgynmln5ml0mv0gn6v0p3f40000gn/T/arduino_build_58877/MotorRotorTest1.ino.hex contains 4326 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.03s
avrdude: verifying ...
avrdude: 4326 bytes of flash verified
avrdude done.  Thank you.
I am rather new to Arduino. And any help is much appreciated!
DoesThisCompute:
I’ve been trying to find answers online and on this forum and found someone saying that this specific part of the error message can be regarded as normal and that it is safe to ignore it.
This is correct.
DoesThisCompute:
This is not an error message. This is output that indicates a successful upload. The problem you’re having is not related to uploading. It’s either a problem with your code or with your hardware.
