i have arduino uno…its 31.378 bytes but shows
avrdude: verification error, first mismatch at byte 0x7800
0x48 != 0xff
avrdude: verification error; content mismatch
Nick i downloaded your file and i put it in libraries file of arduino.
i am trying to upload code but shows me
md5\md5.c.o: In function `md5_starts':
C:\Program Files (x86)\Arduino\libraries\md5/md5.c:40: multiple definition of `md5_starts'
md5.c.o:C:\Users\admin\AppData\Local\Temp\build6123632754648520266.tmp/md5.c:40: first defined here
md5\md5.c.o: In function `md5_process':
C:\Program Files (x86)\Arduino\libraries\md5/md5.c:51: multiple definition of `md5_process'
md5.c.o:C:\Users\admin\AppData\Local\Temp\build6123632754648520266.tmp/md5.c:51: first defined here
md5\md5.c.o: In function `md5_update':
C:\Program Files (x86)\Arduino\libraries\md5/md5.c:174: multiple definition of `md5_update'
md5.c.o:C:\Users\admin\AppData\Local\Temp\build6123632754648520266.tmp/md5.c:174: first defined here
md5\md5.c.o: In function `md5_finish':
C:\Program Files (x86)\Arduino\libraries\md5/md5.c:221: multiple definition of `md5_finish'
md5.c.o:C:\Users\admin\AppData\Local\Temp\build6123632754648520266.tmp/md5.c:221: first defined here
Atmega_Self_Read_Signature.cpp.o: In function `readBootloader()':
C:\Program Files (x86)\Arduino/Atmega_Self_Read_Signature.ino:213: undefined reference to `md5_starts(md5_context*)'
C:\Program Files (x86)\Arduino/Atmega_Self_Read_Signature.ino:218: undefined reference to `md5_update(md5_context*, unsigned char*, unsigned long)'
C:\Program Files (x86)\Arduino/Atmega_Self_Read_Signature.ino:221: undefined reference to `md5_finish(md5_context*, unsigned char*)'
i have not experience with arduino. is it ok to set your file in libraries?
i upload my code----a little description :
i use wifi breakout and sensors for temperature humidity and pressure
i get measurements and send them to my local server
**there are some lines with sntp connection code not all the code for sntp due to memory size
i am trying to reduce the other code and after fill the whole sntp code
i dont know what happens and what it is
mycode includes many examples. it wasn't made by me from the start...
i think that i tried this in the past...i will try again..
do you compile the code ? what happens about size?
