Avrdude error !
Well first i get this code from : (Uno vu meter - YouTube) and when i try to upload my aurduino im getting theese errors ! Please help me i dont understand anything !
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x84
Please do this:
  • (In the Arduino IDE) File > Preferences
  • Uncheck the checkbox next to “Show verbose output during: compilation”
  • Check the checkbox next to "Show verbose output during: upload
  • Click “OK”
  • Sketch > Upload
  • After the upload fails, you’ll see a button on the right side of the orange bar “Copy error messages” (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum’s code tags markup to your reply.
  • Press “Ctrl + V”. This will paste the upload output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
Arduino:1.6.5 (Windows 8.1), Kart:"Arduino/Genuino Uno"
In file included from justvu.ino:2:0:
C:\Users\KuzeyDursun\Documents\Arduino\libraries\FastLED/FastLED.h:17:21: note: #pragma message: FastLED version 3.001.008
pragma message "FastLED version 3.001.008"
Çalışmanız programın 24.198 bayt (75 %) saklama alanını kullandı. Maksimum 32.256 bayt.
Global variables use 1.698 bytes (82%) of dynamic memory, leaving 350 bytes for local variables. Maximum is 2.048 bytes.
Low memory available, stability problems may occur.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\KUZEYD~1\AppData\Local\Temp\build8940501056529470475.tmp/justvu.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xef
avrdude done. Thank you.
Remove any connections to pins 0 and 1 on your Arduino board. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino board, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu. The ports list is only updated when the Tools menu is re-opened, so this step is essential.
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
Removing pin 0 worked thank you very much dude you saved my life <3
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
