avrdude: failed to read all of flash memory, rc=-2
I am now getting these errors. It's the software, not boards as I have two known-good boards sitting on my desk right now, unless both blew at same time. It started happening uploading the ESP8266 code below... now any sketch causes this or similar AVR errors.
I tried restarting the IDE to no avail. I changed USB (serial) ports as well, and of course switched out boards. See verbose error below.
avrdude: stk500_paged_load(): (a) protocol error, expect=0x10, resp=0x00
avrdude: stk500_cmd(): programmer is out of sync
avr_read(): error reading address 0x0000
the selected serial port avrdude: stk500_cmd(): programmer is out of sync
does not exist or your board is not connected
read operation not supported for memory "flash"
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x00
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\matt\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
         Using Port                    : COM4
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\matt\AppData\Local\Temp\arduino_build_327457/wifi2.ino.hex"
avrdude: writing flash (8744 bytes):
Writing | ################################################## | 100% 1.32s
avrdude: 8744 bytes of flash written
avrdude: verifying flash memory against C:\Users\matt\AppData\Local\Temp\arduino_build_327457/wifi2.ino.hex:
avrdude: load data flash data from input file C:\Users\matt\AppData\Local\Temp\arduino_build_327457/wifi2.ino.hex:
avrdude: input file C:\Users\matt\AppData\Local\Temp\arduino_build_327457/wifi2.ino.hex contains 8744 bytes
avrdude: reading on-chip flash data:
Reading | #####
#avrdude: stk500_cmd(): programmer is out of sync
avrdude done.  Thank you.
Code attempted to upload... one of many
#include <SoftwareSerial.h>
#include "ESP8266.h"
SoftwareSerial esp8266Serial = SoftwareSerial(1, 0);
ESP8266 wifi = ESP8266(esp8266Serial);
    // ESP8266
    esp8266Serial.begin(9600);
    wifi.begin();
    wifi.setTimeout(2000);
    /******       Basic commands       ******/
    // test
    /*Serial.print("test: ");
    Serial.println(getStatus(wifi.test()));
    // restart
    /*Serial.print("restart: ");
    Serial.println(getStatus(wifi.restart()));*/
    // getVersion
    char version[16] = {};
    Serial.print("getVersion: ");
    Serial.print(getStatus(wifi.getVersion(version, 16)));
    Serial.print(" : ");
    Serial.println(version);
    // deepSleep
    /*Serial.print("deepSleep: ");
    Serial.println(wifi.deepSleep(5000));*/
    // setBaudrate
    /*Serial.print("setBaudrate: ");
    Serial.println(wifi.setBaudrate(9600));*/
    /******        WiFi commands       ******/
    // setWifiMode
    Serial.print("setWifiMode: ");
    Serial.println(getStatus(wifi.setMode(ESP8266_WIFI_ACCESSPOINT)));
    // getWifiMode
    /*ESP8266WifiMode mode;
    Serial.print("getWifiMode: ");
    Serial.println(getStatus(wifi.getMode(&mode)));*/
    // joinAP
    /*Serial.print("joinAP: ");
    Serial.println(getStatus(wifi.joinAP("ssid", "password")));*/
    // getAP
    /*char ap[32] = {};
    Serial.print("getAP: ");
    Serial.print(getStatus(wifi.getAP(ap)));
    Serial.println(ap);*/
    // quitAP
    /*Serial.print("quitAP: ");
    Serial.println(getStatus(wifi.quitAP()));*/
    // setAPConfiguration
    Serial.print("setAPConfiguration: ");
    Serial.println(getStatus(wifi.setAPConfiguration("ESP8266", "awesomelib", 10, ESP8266_ENCRYPTION_WPA_WPA2_PSK)));
    wifi.restart();
    // getAPConfiguration
    /*char ssid[32] = {};
    char password[63] = {};
    uint8_t channel;
    ESP8266Encryption encryption;
    Serial.print("getAPConfiguration: ");
    Serial.print(getStatus(wifi.getAPConfiguration(ssid, password, channel, encryption)));
    Serial.print(ssid);
    Serial.print(" - ");
    Serial.print(password);
    Serial.print(channel);
    Serial.println(encryption);*/
    // setDHCP
    /*Serial.print("setDHCP STA: ");
    Serial.println(getStatus(wifi.setDHCP(ESP8266_WIFI_STATION, false)));
    Serial.print("setDHCP AP: ");
    Serial.println(getStatus(wifi.setDHCP(ESP8266_WIFI_ACCESSPOINT, true)));*/
    // setMAC
    /*byte mac[6] = {0x11, 0x11, 0x11, 0x11, 0x11, 0x11};
    Serial.print("setMAC AP: ");
    Serial.println(getStatus(wifi.setMAC(ESP8266_WIFI_ACCESSPOINT, mac)));*/
... Sorry hit the 9000 char limit.
Update: I think it is happening when my ESP8266 is connected. I don't have an external 3.3V power supply for it. I removed module and problems went away.
