system
June 23, 2013, 4:29pm
1
Hello,
I just possibliy killed one Nano board, but the behaviour is quite strange, so maybe someone can help me.
I own two Nano boards.
If I try to send a sketch to the possibly damaged Nano, after disconnecting and connecting again, I get the message: "avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x64", "avrdude: stk500_cmd(): programmer is out of sync". If I send it a second time, I get: "avrdude: stk500_getsync(): not in sync: resp=0x00".
I tried to chage to the second one, but got directly: "avrdude: stk500_getsync(): not in sync: resp=0x00". So I tried to reinstall all drivers, rebooted windows several times and finally put both Nanos on the computer, resutling in a new COM-Port. Nevertheless, I always get "avrdude: stk500_getsync(): not in sync: resp=0x00" for both Nano's.
Since I have a Uno simultaneously running without problems, I wonder, what to do now?!
Did I damage the driver just for the Nano's ??
Can anyone help me?
system
June 23, 2013, 7:57pm
2
After again deinstalling and installing the drivers I get for the new Nano following message:
Binäre Sketchgröße: 10.072 Bytes (von einem Maximum von 30.720 Bytes)
D:\Arduino\arduino-1.0.4\hardware/tools/avr/bin/avrdude -CD:\Arduino\arduino-1.0.4\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM15 -b57600 -D -Uflash:w:C:\Users\di29394\AppData\Local\Temp\build4136068767948817022.tmp\VirtWire_RF_Link_Kit_Nano.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "D:\Arduino\arduino-1.0.4\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM15
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: Send: 0 [30] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
avrdude: Send: A [41] . [80] [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81] [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82] [20]
avrdude: Send: A [41] . [98] [20]
avrdude: Recv: . [03]
Hardware Version: 2
Firmware Version: 1.16
avrdude: Send: A [41] . [84] [20]
avrdude: Recv: . [00]
avrdude: Send: A [41] . [85] [20]
avrdude: Send: A [41] . [86] [20]
avrdude: Send: A [41] . [87] [20]
avrdude: Send: A [41] . [89] [20]
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00] [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00] [20]
avrdude: Send: P [50] [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: u [75] [20]
avrdude: Recv: . [14] . [1e] . [95] . [0f] . [10]
################################################## | 100% 0.02s
avrdude: Device signature = 0x1e950f
avrdude: Send: V [56] . [a0] . [03] . [fc] . [00] [20]
avrdude: Send: V [56] . [a0] . [03] . [fd] . [00] [20]
avrdude: Send: V [56] . [a0] . [03] . [fe] . [00] [20]
avrdude: Send: V [56] . [a0] . [03] . [ff] . [00] [20]
avrdude: reading input file "C:\Users\di29394\AppData\Local\Temp\build4136068767948817022.tmp\VirtWire_RF_Link_Kit_Nano.cpp.hex"
avrdude: writing flash (10072 bytes):
Writing | avrdude: Send: U [55] . [00] . [00] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [0c] . [94] . [a4] . [00] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [cc] . [00] . [0c] . [94] y [79] . [07] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [a4] . [0a] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [7f] . [0c] . [0c] . [94] . [cd] . [0c] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [cc] . [00] . [0c] . [94] . [cc] . [00] . [07] c [63] B [42] 6 [36] . [b7] . [9b] . [d8] . [a7] . [1a] 9 [39] h [68] V [56] . [18] . [ae] . [ba] . [ab] U [55] . [8c] . [1d] < [3c] . [b7] . [cc] W [57] c [63] [20]
avrdude: Recv:
avrdude: Send: V [56] @ [40] . [00] . [00] . [0c] [20]
avrdude: Recv:
Does this help?
system
June 24, 2013, 6:05am
3
Did you change the settings in IDE>Tools>board and IDE> tools> programmer ?
I'm not sure about the UNO, but between my Mega2560 and Nano, I always have to change these settings.
system
June 24, 2013, 6:50am
4
Yes, I tested all programmers, but none worked.
Meanwhile I changed to another computer (win 7x64) and get the "avrdude: stk500_cmd(): programmer is out of sync" message for the probably damaged Nano (I put probably 12 V to a digital IO pin, but not really sure). So this could mean, that the Nano is not probably but definitely damaged.
The other Nano runs without problems on this computer, i.e. should also work on my computer!
Is it possible, that I damaged something within windows 7x64 on my computer?
So, which drivers/services etc. are relatet to FTDI-USB communication?
Maybe I deactivated something in windows. A few moths ago, e.g. I forced windows to deactivate the USB port due to a too high voltage but for this I got a message from windows. Now I got no (obvious) message.
I'm really unhappy, since I'm close to the finish of my first larger arduino project.
system
June 24, 2013, 11:17am
5
Hmmm ... now I'm back home and tried again the undamaged Nano - and it works ?!?!?!?!?!?!?!
So I let the damaged one away from the computer to avoid corrupting the system again.
I don't really unterstand what happend.
Maybe the second Nano (which was in factory state as I tested it) was initialized in a certain kind and that's why it now works also at the other computer?!?!.
