AVRdude Not in synchronization
I have always got the error when I use SPI communication :confused: :confused: >:(
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00 avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00 avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00 avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
Last time I had changed the SPI connetion from hardware to sofware and also Changed the version of the Arduino IDE.... but again the same issue.. Also I found lot of post on internate about the same problem.. so what is the proper solution? I have none of the following issue.. >:( >:(
1 A wire is connected to pin0 2 You have the wrong COM port selected (the IDE does not see your board) 3 Your Arduino drivers are not set properly.
What exactly are your trying to do? The IDE communicates by a serial connection and does not use SPI. Are you using a programmer?
