avrdude problems.
Hello! Ive sat down for about 2 hours now trying to figure out what in the hell is wrong with my arduino nano. i was working with it some time ago, everything went on well, then i accidentaly touched 5v to ground pin for like, i dunno, half a second. i restarded it, everything worked well. i started loading up bitmap and it was taking really long time, started crashing, but still managed to upload sketches, now nothing works.
Bootloader doesnt load, blank sketches dont work, no pins touch each other, tried different programmers, diferent coms etc.
one time it says it cant connect to coms as the access is forbidden, the next time it says that there are problems with programer. i dunno what to do anymore.
here's the error:
Linking everything together...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\al\AppData\Local\Temp\arduino_build_550302/sketch_dec18a.ino.elf" "C:\Users\al\AppData\Local\Temp\arduino_build_550302\sketch\sketch_dec18a.ino.cpp.o" "C:\Users\al\AppData\Local\Temp\arduino_build_550302/..\arduino_cache_217909\core\core_arduino_avr_nano_cpu_atmega328old_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\Users\al\AppData\Local\Temp\arduino_build_550302" -lm
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\al\AppData\Local\Temp\arduino_build_550302/sketch_dec18a.ino.elf" "C:\Users\al\AppData\Local\Temp\arduino_build_550302/sketch_dec18a.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\al\AppData\Local\Temp\arduino_build_550302/sketch_dec18a.ino.elf" "C:\Users\al\AppData\Local\Temp\arduino_build_550302/sketch_dec18a.ino.hex"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-size" -A "C:\Users\al\AppData\Local\Temp\arduino_build_550302/sketch_dec18a.ino.elf"
Sketch uses 444 bytes (1%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Users\al\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\al\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM8 -b57600 -D -Uflash:w:C:\Users\al\AppData\Local\Temp\arduino_build_550302/sketch_dec18a.ino.hex:i
An error occurred while uploading the sketch
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\al\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM8
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x23
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x23
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x23
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x23
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x23
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x23
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x23
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x23
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x23
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x23
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Select Tools > Processor > ATmega328P and then try uploading again.
dainyzas:
Please provide a detailed explanation of what you mean by that.
pert:
still doesnt work. Already tried that. it gives this error:
Using Port : COM8
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x34
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x34
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x34
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x34
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x34
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x34
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x34
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x34
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x34
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x34
pert:
error while trying to burn bootloader:
Using Port : COM8
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
Error while burning bootloader.
dainyzas:
Do you have an ISP programmer connected to the ICSP header on your Nano (for example)?
pert:
I dont. The thing is, so far i didnt need it. Every sketch uploaded with no problems till now
The Burn Bootloader process requires an ISP programmer. If you don't have one connected, then the process will always fail. So that error you're getting is normal and expected.
Most likely you destroyed your Nano and you're best to just throw it in the salvage bin and get a new one. However, you could try to connect an ISP programmer and burn the bootloader if you like. The link I posted in my previous reply is a tutorial for how you can use a spare Arduino board as an ISP programmer if you don't own a dedicated programmer.
pert:
god dammit..alright, thank you!
