I have a bunch of Pro Minis. Looking them over this morning and I see that some have the pins switched. DTR on one side and then the other. Make sure the pin layout for the FTDI232 is the same on each Pro Mini you connect. Use the Reset button just as the sketch is uploaded. Double check the TX0 and RX0. Run the loopback test on the FTDI.
