avrdude reset board
Hi, im having an problem with avrdude; when i want to read or write flash or eeprom, i need to
reset my board with button a just a few moments before i push enter key on keyboard(on enter avrdude executes command). If
I dont reset board, computer cant communicate with board, like its not connected.
How can i bypass this ?
If
This is not how it should be. You are probably doing something wrong but you will have to explain in more detail what you are doing to give us a clue about putting you right.
Ok, for example when i try to do this i get the results described in above post:
avrdude -p m2560 -c stk500 -U flash:r:flash.hex:i -P COM2
yes, i have an arduino mega and port is com2 :wink:
Just to mention, within Arduino IDE it works perfectly(no need for resetting the board).
I think you are seeing (or not) the effect of the auto reset. The DTR line is attached to the reset line by a capacitor and gives it a reset every time the serial port is opened or closed. This kicks off the boot loader. It looks like this is not happening in your setup. Try including a command to open the serial port.
Yes, its probably that, do u have any ideas how can I fix it?
Im developing an application for arduino which writes something to serial port using avrdude.
No one replies ?
I found that i have to trigger a reset signal to the board (DTR signal)
I would like to know how its done within the IDE so I can do it too with avrdude ???
You need a recent version of avrdude (5.11 and up) and use
avrdude -c arduino ...
