Hi everyone, I'm new to this forum, I have an arduino nano and I can't upload a program. the question is that the pec recognizes the device as CH340 but in the arduino ID it throws me this avrdude: ser_open(): can't set com-state for "\.\COM10". I would appreciate your help, it is worth mentioning that on the arduino board the driver chip does not specify what type it is
I moved your topic to an appropriate forum category @oskr0309.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Hi @oskr0309.
There were some previous reports of this "can't set com-state for ..." error occurring specifically when using boards like yours that have the CH340 USB chip. It seems that a driver upgrade included in a recent Windows update is the cause of this problem.
The affected users have reported that doing a "roll back" to an older version of the driver was an effective workaround. You can give that a try.
I'll provide instructions:
- Open this tutorial from SparkFun in your browser:
https://learn.sparkfun.com/tutorials/how-to-install-ch340-drivers/all#drivers-if-you-need-them
ⓘ We are using this tutorial as a source for an older version of the CH340 drivers. Generally I recommend only obtaining drivers from the manufacturer of the device, but WCH does not provide older versions of their drivers and SparkFun is trustworthy. - Click the "Windows (EXE)" link you see in red under the "Drivers (If You Need Them)" section of the tutorial.
- Wait for the download to finish.
- Run the downloaded
CH341SER.EXEfile. - A "User Account Control" dialog may now appear asking "Do you want to allow this app to make changes to your device?". Click the "Yes" button.
- A "DriverSetup(X64)" dialog will appear. Click the "INSTALL" button in the dialog.
- Wait for the driver installation to finish, as indicated by the appearance of a "Driver install success!" dialog.
- Click the "OK" button in the "Driver install success!" dialog.
- Click the X icon at the top right of the "DriverSetup(X64)" dialog to close it.
- Close Arduino IDE if it is running.
- Connect the Arduino board to your computer with a USB cable.
- Open the Windows Device Manager.
- Select View > Devices by type from the Device Manager menus.
- Open the "View" menu.
- If there is a ✓ to the left of the "Show hidden devices" menu item, click on "Show hidden devices" to disable it.
- Open the "Ports (COM & LPT)" section of the Device Manager tree.
- You should see a port identified as "USB-SERIAL CH340 (COM_n_)" under the "Ports (COM & LPT)" section (where "COM_n_" is some serial port e.g., COM4). Right click on that item.
A context menu will open. - Select the "Drivers" tab of the "USB-SERIAL CH340 (COM_n_) Properties" dialog.
- You will see a "Roll Back Driver" button in the dialog. If it is not clickable, perform the following instructions:
- Select "Update driver" from the context menu.
An "Update Drivers Device - USB-SERIAL CH340 (COM_n_)" dialog will open. - Click on "Search automatically for drivers" in the "Update Drivers Device - USB-SERIAL CH340 (COM_n_)" dialog.
- You should now see the driver installation wizard update the driver. Wait for the update to finish, as indicated by the message "Windows has successfully updated your drivers" in the dialog.
It is possible you will instead see the message "The best drivers are already installed". If so, please stop following the instructions here and reply on the forum thread to let me know. I'll provide alternative instructions you can follow. - Click the "Close" button in the "Update Drivers Device - USB-SERIAL CH340 (COM_n_)" dialog.
- Click the "Roll Back Driver" button in the "USB-SERIAL CH340 (COM_n_) Properties" dialog.
The "Driver Package rollback" dialog will open. - Click the radio button next to "My apps don't work with this driver" in the "Driver Package rollback" dialog .
- Click the "Yes" button.
- Click the "Close" button in the "USB-SERIAL CH340 (COM_n_) Properties" dialog.
Now start Arduino IDE again and repeat whatever you were doing before when you encountered that error. Please reply here to let us know whether the error still occurs.
ok my sincerest apologies
The aforementioned did not work for me, also Windows does not let me revert to the previous driver
Thank you very much for answering, I will try to go back to previous versions of Windows to verify if it is only with Windows 11. Thank you
I'm not sure I understood correctly what you mean by this. Please provide a detailed explanation of what you mean by "did not work", including:
- What did you do?
- What were the results you expected from doing that thing?
- What were the results you observed that did not match your expectations?
Make sure to include the full and exact text of any error or warning messages you might have encountered.
perform all the steps to follow previously mentioned, reinstall the CH341 controller, but windows does not let me go back to the previous controller, also before going to the forum I bought another arduino nano thinking that the one I had was defective, it should be noted that it is only happening to me With this version of the arduino board (nano) the other boards have worked correctly for me, both generic and original. I hope something comes to light to be able to use this device
I was able to solve the problem by replacing the drivers manually from the windows drivers folder. thank you
Nice work on finding a solution. Thanks for taking the time to post an update!
Regards,
Per
