Avrdude: ser_setspeed(): tcsetattr() failed - Mini Pro
I am lost.... I hope you can help me.
When I program a Mini Pro, which can be a 3.3v or a 5v for the first time, it works
When I want to reprogram the same boards Mini Pro, it doesn't work...
I get the following errors:
avrdude: ser_setspeed(): tcsetattr() failed
avrdude: ser_open(): can't set attributes for device "/dev/cu.usbserial-110": Invalid argument
Failed uploading: uploading error: exit status 1
The program on the Mini Pro which was loaded before still runs, so the board isn't bricked.
I have tried to re-upload the boot loader using a Uno as ISP it doesn't work either.
I havent got this issue when I program a UNO with the same code.
I am using IDE 2.0 rc9, running on a MacBook Pro M1 with Monterey 12.3
I use a USB C to USB A adapter regardless the Ardoino board I am using (UNO, Nano usually and more recently the Mini Pro.)
Ah, I just got a slightly different error now, although I changed nothing:
Failed uploading: uploading error: exit status 1avrdude: ser_setspeed(): tcsetattr() failed
Please, I hope somebody can help, I am desperate to make this work.
Thanks in advance,
Charles
I guess the serial device changed when the board did reset. Try to re-select the correct serial device and re-upload.
Is your serial port occupied by another program? For example a serial monitor program will lock access to the port.
Hi, thank you for your replies. I felt I was in Windows... But I am on a Mac... I just had to restart IDE, and force "quit" in the "activity monitor and it worked...
On one Mini Pro however, I still can't program it, and the previous code uploaded on it still runs fine...
I am getting the following errors, is there a trick to be able to program it again ??
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
Charles
A Mini Pro doesn't have an USB connector, so there is much potential of doing the connection from the Mac to the board wrong. As you didn't provide a wiring diagram I strongly guess you did the wiring wrong.
I thought I explained better, sorry.
I am using an adapter to connect the mini pros to usb on my Mac. (This is actually obvious)
What I might have not explained well is the fact that I can upload sketches to other mini pro boards without issues. I have this problem with one board only !
The application I loaded previously on this mini pro still runs but I can’t anymore upload anything to it.
I can’t change the boot loader either using a uno as isp.
What exact adapter are you using? That might heavily influence the result of an upload. Another factor may be the length and quality of the wires/cable used to connect the adapter to the Pro Mini.
I guess you soldered some headers to the Pro Mini to be able to connect the adapter, so the soldering is important too, a bad soldering on one single pin might show such problems.
I am using an adapter I bought at the same time. No wires, it just connects to the mini pro through headers.
I checked the soldering on both the adapter and the board and on both sides they are ok.
Post a sharp picture of that board and of the adapter!
