avrdude: ser_open(): can't open device "\\.\COM3": Access Denied
I just got my Arduino Uno and I can't upload anything >:( . I don't have anything else that uses ports in my computer. I've tried reinstalling the Arduino program 3 times, Changing the COM, nothing works. >:( :frowning: >:( :frowning: :confused: >:(
Check device manager - make sure the device is working properly, no yellow triangle. If yellow triangle, fix driver problems and try again.
If you are using a clone with a CH340G serial interface chip (look at part number on chip next to usb port), you need to download and install the drivers for that. ( CH341SER is the file name, google it).
If you are using v 1.6.8 of the IDE, uninstall it and try 1.6.5r5. 1.6.8 has a bug relating to how it interacts with the serial ports under windows that can cause access denied errors (among other things)
If you downloaded v1.6.8 and you are Windows, that release has a problem with making Serial busy.
There is no Sticky on v1.6.8 but several posts on this issue.
I suggest removing 1.6.8 and installing 1.6.5 (r2).
Welcome to Arduino.
