I bought my arduino in University, hooked it up and it worked fine. (Everything was installed already)
Came home, installed it, plugged it in and nothing.
In the device manager I had unrecognised usb port(arduino), uninstalling/reinstalling the compiler didn't work, neither did installing "dpinst-amd64" from driver's folder or CDM drivers. I ended up finding a solution on this forum, where you locate the driver manually, I live in europe and my unit is UNO so I chose the Genuino Uno driver, but this error followed after I tried to compile "blink" example.
avrdude: ser_open(): can't open device "\.\COM7": The system cannot find the file specified.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I tried manually changing port from device manager, I tried every solution I could find on this forum for this issue and nothing. I only see one COM port, the one assigned in device manager (I have the impression I should be seeing more from other comments with the same issue).
Whenever I plug it in a different usb port I have to locate drivers again, I've tried both genuino and arduino uno.
Thanks in advance.
