avrdude: ser_open(): can't open device "\\.\COM3" Com found but still issues!
This problem has been posted quite often but i believe that mine is different.
Most of these error messages can be solved by changing the Coms. Didn't work for me.
The weird thing is that I tested another board(exactly the same product) and it worked fine.
The things I use:
-Arduino UNO R3
-USB Cable (tried another one as well)
-Windows 7 64-Bit
-Arduino IDE 1.6.5
Arduino: 1.6.5 (Windows 7), Board: "Arduino Uno"
Sketch uses 450 bytes (1%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: ser_open(): can't open device "\.\COM10": Das System kann die angegebene Datei nicht finden.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
enabled in File > Preferences.
"Das System kann die angegebene Datei nicht finden." translates to "No such file or directory".
(I'm german)
I appreciate every help I get,
Smagel
But what makes you sure COM10 is indeed the port you need?
Well, nothing? How do I find out which port I need?
hello. general information. in my case this issue came due to non data cable... XD just sayin. had nothing in devicemanager happenning XD
