avrdude: ser_open(): can't open device
Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 1868 bytes (5%) of program storage space. Maximum is 32256 bytes.
Global variables use 188 bytes (9%) of dynamic memory, leaving 1860 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "\.\COM4": The system cannot find the file specified.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
ak8962726177:
You have the wrong board selected, you need Tools > Board > Arduino Nano
There are two different bootloaders for the Nano, either Tools > Processor > ATmega328P or Tools > Processor > ATmega328P (Old Bootloader), you will have to try both to see which is correct for your board.
This is the second time I've had to split your hijack post off a thread @ak8962726177. This is your final warning. If you do it again, I'm going to give you an account suspension.
how to tare the analog reading by use push switch .
ReadAnalogVoltage
Reads an analog input on pin 0, converts it to voltage, and prints the result to the serial monitor.
Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
This example code is in the public domain.
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (5.0 / 1023.0);
// print out the value you read:
Serial.println(voltage);
