Avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xa4
Hello,
Help me with this I am programming a robotic arm using Arduino UNO with the pins Rx and Tx from the robotic controller and every time when I upload the code I am getting this error with different last numbers avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x21 such as 0x26, 0x10, 0xe5. debug this error it will help me in project.
Please describe that process some more.
I figured out some how and moved the robot by changing the pins on the Arduino board. What I did is the pins RX and TX from the robotic controller I have connected them to PIN 9 and 10 on the UNO board and program got uploaded and other thing is when I am writing a program to 6 servo motors I am able to move only 3 motors I am unable to move all the six in the arm. I have difficulty in constraining the angles and robot positions are in between 500 to 2500. do you have any Idea?
How about posting a wiring diagram?
When you connect the Uno to a PC, are the other parts of the system connected to the 5V pin of the Uno?
Pins 0 and 1 are used for upload (via the TTL-to-USB adapter on the board). If you connected anything to them, it might interfere with the upload.
