avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
friends,
An error occurred while uploading the sketch
Im using arduino Uno R3 and getting this error all of a sudden , when i try to upload the code.
everything working fine:
cable, led blinking, tried hitting reset before and after uploading and serial port selection..
but still the problem persists...
what might be the faault? bootloader/board/programmer or ?...
Hey , i have the same problem , did you find any solution??
I had this problem, I was using the HC-05 bluetooth module and got this error when it was connected while i was trying to upload a sketch! Did you try uploading sketch with nothing connected to the board?
I have the same problem with Arduino Pro clone (ATMega168 16M/5V). I have at least 4 of them and 2 act like this.
