avrdude: stk500_getsync(): not in sync: resp=0x00 Error (SOLVED)
Hello
I was working with Arduino, everything worked fine. But i cant program it now. The error is this:
Binary sketch size: 8864 bytes (of a 14336 byte maximum) avrdude: stk500_getsync(): not in sync: resp=0x00
I have Windows 7, any solutions? i am desperate :S
Thanks
PD: I use COM17 ( is correct ) and Atmega 168 ( correct too, because Atmega 168-20PU
i am desperate
You are also in the wrong place. This is not a Programming issue.
PaulS:
i am desperate
Sorry but...
Programming Questions Understanding the language, error messages, etc.
The correct place is "Installation & Troubleshooting"? Sorry, i am confused for "error messages".
Sorry but...
What code were you compiling or linking when you got that error message?
PaulS:
Sorry but...
Yes, fail me, the correct place is "Installation & Troubleshooting". Sorry.
Clemen89: The correct place is "Installation & Troubleshooting"? Sorry, i am confused for "error messages".
Before you start posting messages in 16 point type in the Programming section, maybe you should read:
Read this before posting a programming question
Clemen89: I was working with Arduino, everything worked fine. But i cant program it now. The error is this:
Clemen89: First, sorry for my english, i promise that i will learn the idiom jeje.
I press connect in easyVR commander and "Could not detect device connected to port COM17". In the arduino 1.0 i use COM17 for programming arduino.
I dont know what is the problems, i am desperate, some help?
Is this a cross-post? And are you still desperate?
Facepalm...
Can't you see that are different problems? And yes, i am desperate, because first i find information and after post.
I only needed help. But you seem to children.
Is the correct place? I am desperate? This is the important questions... facepalm. 12 years old...
Thanks for the help.
Are you saying you are 12 years old? OK well we’ll cut you some slack then…
Have you read this?
http://www.arduino.cc/en/Guide/Troubleshooting#upload
What board do you have? How is it connected? Maybe you plugged in a new device and your Arduino is no longer COM17.
What did you do just before it stopped working? Details please.
Try not to shout at people who are trying to help you.
What board are you using? And what's the full name of the board menu item you have selected?
Also, definitely check out the troubleshooting guide.
Hi
Diecimila with Atmega 168 and i select “Diecimila or duemilanove w/ Atmega 168”. I tried in other computer and the same error.
When i disconnect and reconnect the arduino to pc the led ( led associated to pin 13 ) dont blink, only power led is on ( green led ). The bootloader is failing maybe?
I connected arduino to usb in pc. Everything worked fine until today… i was working with VRbot and arduino.
I read the guide anted to ask in forum.
Thanks
EDIT:Ah, I tried too with arduino 0019, and the error is:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
Have you got a second board handy? You could try running the sketch here on the one that works:
http://www.gammon.com.au/forum/?id=11633
That will detect the chip signature on your "faulty" board, and also the MD5 sum of the bootloader. This will confirm a few things, like if it is reacting at all.
[quote author=Nick Gammon link=topic=106873.msg802657#msg802657 date=1337720056] Have you got a second board handy? You could try running the sketch here on the one that works:
That will detect the chip signature on your "faulty" board, and also the MD5 sum of the bootloader. This will confirm a few things, like if it is reacting at all. [/quote]
Thanks!
But I havent got other board :(.
Right well I repeat my question:
I was working with VRBot ( in arduino of course ), only was using the digital pins 12 and 11, 5V and GND. Well, and two leds in digital pins 8 and 9. Nothing more.
I changed my sketch and appeared this error when i was uploading the new sketch.
Thursday, friday and monday morning everything worked fine.
Thanks again!
Tell us about the resistors you used.
[quote author=Nick Gammon link=topic=106873.msg803082#msg803082 date=1337759541] Tell us about the resistors you used. [/quote]
I have not used resistors, well only VRBot, one photo:
This device and two leds in pins 9 and 8.
Hi again
The problem was bootloader.
I found this tutorial and it solved the problem:
http://www.geocities.jp/arduino_diecimila/bootloader/index_en.html
Don't need more boards or programmers, is great.
Thanks all for the help and replys!
i found a different solution to the stk500_ ... error, but don't know where to post it. somebody pointed out to the young fellow that he was in the wrong place to discuss this, but i didn't see a direction to where he should be. how about telling me so i can post what worked for me.
I got the same error that means arduino board is not communicating with the pc or there is something wrong in the bootloader what i did to resolve this issue was checking weather the arduino board and the communication port is correctly selected or not then i re-extracted the arduino-1.5.6-r2 and the sketch got uploaded
