avrdude: stk500_getsync(): not in sync: resp=0x00 Possible Serial Port error?
Hi, recently I've been toying around with the Arduino Uno. The booklet said that a recommended Serial Port would be COM3 or above, but I was only presented with the option of COM1. Not quite sure why that is. After typing out the first activity, the blinking LED, the code compiles, but then doesn't send to the board, giving me error code avrdude: stk500_getsync(): not in sync: resp=0x00. Does anyone know how to fix the serial port, or any other solutions?
Have you installed the drivers for the board?
Post a link to where you got the board from, and what OS you have.
ChilliTronix: Have you installed the drivers for the board?
The drivers installed alongside the arduino software, unless those weren't the ones I need? I'm running Windows 7, this is the link: http://arduino.cc/en/Main/arduinoBoardUno.
Did you buy the board from the Arduino store?
Use the Control Panel>Device Manager in your windows. Under COM/LPT it will show you the Arduino COM Port.
You could also have wrongly wired your Arduino board, in that case detach your GND cables from your board before uploading your sketch. But do re-wire your cables too ;)
