avrdude: stk500_getsync(): not in sync: resp=0x00
I recently just bought the Arduino Uno. I am using Windows 7.
After trying to upload the "blink" program, I am getting the following error:
I have looked all around the web on this and understand that it is some type of serial port problem. I have done the following things:
  1. Uninstall and re-install Arduino IDE
  2. In Arduino IDE: Tools --> Board --> Arduino Uno
  3. In Arduino IDE: Tools --> Serial Port --> COM7
  4. In my device manager, I can see my "Arduino Uno (COM7)" under PORTS (COM & LPT)
I don't know what else could be the issue.
http://forum.arduino.cc/index.php?topic=73748.0
Pass or fail?
Fail. What I send was not echoed back.
Have you ever been able to upload to the Uno?
Yes, I was able to upload the Uno for quite a while. I was using COM4.
The only thing I can remember doing to it was disconnecting the USB while one of my systems was running. This doesn't seem like it should effect anything, but I started getting the "avrdude: stk500_getsync(): not in sync: resp=0x00" error immediately afterwards.
After this instance, the Arduino IDE quit recognizing that I had any serial connection (the "Serial Port" menu under Tools was grayed out). Since then, I have uninstalled and reinstalled the latest IDE and my Arduino is now attempting to interface with COM7.
The ATmega16U2 may have forgotten its purpose. If you have a second board I suggest trying to re-flash it.
Panther25423:
Let me know, last program being uploaded by you. I think your boot loader has been crashed. You might uploaded infinite loop program.
Also check whether any error or not. As you telling intially port being showing 4 and now it showing 7 . It bit confuses here.
