Have seen a post that is sort of like this. The responder asked the poser to copy the error message but there did not seem to be any resolution.
Arduino: 1.8.12 (Windows Store 1.8.33.0) (Windows 10), Board: "Arduino Uno"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program \ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-size" -A "C:\Users\ALLEN~1.PIT\AppData\Local\Temp\arduino_build_617238/PIR_Arduino_BD437g_Two_Modules_210220.ino.elf"
Sketch uses 1022 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 13 bytes (0%) of dynamic memory, leaving 2035 bytes for local variables. Maximum is 2048 bytes.
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe2
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe2
avrdude done. Thank you.
Don't think the problem is w the COM port. And I had the greyed out PORT menu option issue but fixed that.
Have tried several different boards, cables, and computers.
Remove any connections to pins 0 and 1 on your Arduino board. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu. Note that some boards have similar names, but are not interchangeable. Examples include "Arduino Uno" vs. "Arduino Uno WiFi" vs. "Arduino Uno WiFi Rev2", "Arduino Nano" vs. "Arduino Nano Every" vs. "Arduino Nano IoT" vs "Arduino Nano 33 BLE", "Arduino Duemilanove" vs. "Arduino Due".
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino board, you can find it like this:
Unplug your Arduino board from the computer.
Tools > Port
Note the ports, if any, listed in the menu.
Close the Tools menu. The ports list is only updated when the Tools menu is re-opened, so this step is essential.
Plug your Arduino board into the computer.
Tools > Port - The new port listed in the menu is your Arduino board.
I have the same problem trying to program an Arduino Mini :-
Uploading ‘SkySurferMotor’ to ‘ATmega328P (Arduino Mini)’ using ‘COM3’
The uploader returned an error
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x59
…etc…
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x59
However, I tested the download to a Nano, Uno, and Mega2560 and they all worked fine.
The Mini is interfaced by using a Sparkfun Beefy, and I have successfully used this to program the Mini a matter of a few weeks ago, so I think something has changed in the Arduino Dev environment, or (Dare I say it) Windows 10.
