avrdude: stk500_recv() on raspberrypi linux commandline
sudo avrdude -v -p atmega328p -c arduino -P /dev/ttyAMA0 -b57600 -D -U flash:w:app.hex:i
avrdude: Version 6.1, compiled on Jul  7 2015 at 10:29:47
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/etc/avrdude.conf"
         User configuration file is "/root/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyAMA0
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done.  Thank you.
why this not work? Arduino UNO v3
The Uno by default uses Optiboot, which uploads at 115200 bps, not 57600, assuming you have not modified the board to run at a different speed.
You may also have connected it wrong - It's really easy to hook up TX and RX backwards. Like, really easy.
