Avrdude stk500_recv - Problem APC220
Good evening fellow
I have a problem in APC220 , I can not make it work in any way , all connections are correct , rx -tx tx- rx , 5v and gnd .
Both adapters are using the same parameters in RFMagic .
I use an Arduino UNO R3 ( ATmega328 ) .
When compiling the file the IDE presents Loading … however the error as image.
I’m unplugging the rx to compile.
I appreciate the attention and I’m waiting !
Sorry my english , I’m from Brazil and I am using translator
leowalkiw: Good evening fellow I have a problem in APC220 , I can not make it work in any way , all connections are correct , rx -tx tx- rx , 5v and gnd . Both adapters are using the same parameters in RFMagic . I use an Arduino UNO R3 ( ATmega328 ) . When compiling the file the IDE presents Loading ... however the error as image. I'm unplugging the rx to compile. I appreciate the attention and I'm waiting ! Sorry my english , I'm from Brazil and I am using translator
ok,
maybe your programmer is not resetting the RFMagic correctly, During the last part of the compilation, as soon as you see 'sketch use', touch the reset button on the RFMagic device.
If the RFMagic has a bootloader installed it should respond to the programmer.
If your RFMagic board does not have a bootloader installed you will have to use an ISP programmer connected to the ISP header (2x3pin).
Chuck.
