avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() a
This is error i get when i try to upload my code to Arduino Uno (I checked the upload box in Preferences>Show verbose output during and unchecked the compilation box ):
Arduino: 1.8.10 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 1902 bytes (5%) of program storage space. Maximum is 32256 bytes.
Global variables use 186 bytes (9%) of dynamic memory, leaving 1862 bytes for local variables. Maximum is 2048 bytes.
D:\Veljkovo\Programiranje\Arduino\hardware\tools\avr/bin/avrdude -CD:\Veljkovo\Programiranje\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Vlada\AppData\Local\Temp\arduino_build_302813/Test.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "D:\Veljkovo\Programiranje\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x22
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x22
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x22
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x22
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x22
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x22
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x22
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x22
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x22
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x22
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
The Upload also takes like 2 minutes.
Remove any connections to pins 0 and 1. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
I did that. Nothing is connected to pins 0 and 1 and the board and port are correct.
Also i have HC-SR04 Ultra Sonic sensor connected.
This is my code:
  int trig=7;
  int echo=8;
  float vreme;
  float daljina;
  pinMode(trig,OUTPUT);
  pinMode(echo,INPUT);
  digitalWrite(trig,LOW);
  delayMicroseconds(5);
  digitalWrite(trig,HIGH);
  delayMicroseconds(10);
  vreme=pulseIn(echo,HIGH);
  daljina= (vreme/2) / 0.0343;
  Serial.print("Udaljenost: ");
  Serial.print(daljina,"cm\n");
But it won't work with any code.
Translation:
vreme means time
daljina means distance
The code is irrelevant to your upload problem. It would happen with any code.
Was there ever a time when you were able to upload to this Uno?
I was able to upload "blink code" before i plugged in the sensor.
The vcc on sensor i connected to 5v, gnd to gnd and trig and echo are connected to digital pins.
Disconnect all external wiring, modules, sensors, shields, etc. from the Uno and then try uploading again. Does that make the problem go away?
no :frowning:
         Using Port                    : COM3
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xa0
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xa0
I also pressed the red button on arduino
I restarted the computer and now it works :smiley: Thanks for the effort!!!
I'm glad to hear it's working now. Thanks for taking the time to post an update. Enjoy!
