avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() a
We are having an issue uploading blink code to our arduino uno and the "on" light on the arduino uno isn't turning on when we plug it in. We are using a arduino uno rev 3. The light would turn on with our old arduino uno. This is the error we got.
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc3
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM1 -b115200 -D -Uflash:w:C:\Users\Cole\AppData\Local\Temp\arduino_build_459568/Blink.ino.hex:i
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM1
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x31
avrdude done. Thank you.
option enabled in File -> Preferences.
Can you chech the ports under tools, as it is unlikely that COM1 is correct.
There is only COM1 no others are shown. Do we have to update a driver?
Probably, is it an official Arduino or a clone? If it's a clone, please tell us what chip is next to the USB port.
Its an official arduino uno rev3. We bought it from the official site, the chip is a ATMEL MEGA16U2 2013 TH 20133AE
Make sure the USB cable is completely plugged into both the Arduino board and the PC.
You may have a damaged/defective or charge-only USB cable. Try a different cable.
