Hi guys,
I’ve just run into this error and now the board wont update. It was working fine 5 minutes ago and would upload now it wont.
I’ve tried different USB cables and the trouble shooting guide on the Arduino webside with no prevail.
The system I’m using is Win 7 64-bit and Arduino 1.6.1 IDE and also tried 1.0.5 r1. I have also tried it on a Win 8 machine with Arduino 1.6.1
The board I’m using is a Freetronics Eleven R3 V2.0
The com port is selected right so is the board type.
All the correct drivers are installed and both the device manage and IDE pick up that its COM4 and I also tried changing the com port in device manager and then in the IDE and it still didn’t work.
When uploading code the RX light blinks 3 times then after a while blinks again the TX light doesnt blink at all.
I tried doing a loog-back through serial manager and everything seemed to be working.
I tried shift+upload and i get this error
avrdude: Version 6.0.1, compiled on Jan 15 2015 at 16:58:43
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino/hardware/tools/avr/etc/avrdude.conf"
Using Port : usb
Using Programmer : stk500v2
avrdude: usbdev_open(): did not find any USB device "usb"
If you have any other advice on what I should do, it would be greatly appreciated
Thanks in advance.
This is the error code I get when trying to upload the Blink example code:
Arduino: 1.6.1 (Windows 7), Board: "Arduino Uno"
Sketch uses 450 bytes (1%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Arduino/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\Nathan\AppData\Local\Temp\build7337161514492371573.tmp/sketch_mar24a.cpp.hex:i
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xb0
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xb0
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xb0
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xb0
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xb0
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xb0
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xb0
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xb0
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xb0
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xb0
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
