avrdude: stk500_recv(): programmer is not responding resp=0x50
estoy usando el FTDI232rl serie USB a Serial pero no me carga mis programas, ya intente instale de nuevo los drivers y cambie el puerto y me sigue apareciendo lo mismo. Y en la placa un Led medio parpadea al intentar subirlo pero no lo hace. Este es error que me manda:
avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x50 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x50 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x50 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x50 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x50 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x50 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x50 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x50 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x50 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x50 Problema subiendo a la placa. Visita http://www.arduino.cc/en/Guide/Troubleshooting#upload para sugerencias.
por favor si me pueden dar algĂșn consejo de que hacer
thaily: estoy usando el FTDI232rl serie USB a Serial pero no me carga mis programas, ya intente instale de nuevo los drivers y cambie el puerto y me sigue apareciendo lo mismo. Y en la placa un Led medio parpadea al intentar subirlo pero no lo hace. Este es error que me manda:
por favor si me pueden dar algĂșn consejo de que hacer [/quote
For this problem will solve through to driver installation Reinstall software Plug Arduino UNO board Go to control panel, Manger Select com and right click update driver OR install driver If re installation time por may be change com3 to com 11 select BOTH side port
For this problem will solve through to driver installation Reinstall software Plug Arduino UNO board Go to control panel, Manger Select USB LT.....com and right click update driver OR install driver If reinstallation time port may be change com3 to com 11 select BOTH side port
Harikumar. K Kerala Kannanakuzhy
I also solved same problem For this problem will solve through to driver installation Reinstall software Plug Arduino UNO board(then detect and install driver ok May be a chance to change port com3 to any number... Ok) Go to control panel, Laptop System Manger Select com LT.... and right click update driver OR install driver If reinstallation time port may be change com3 to com11 .....OR any number select BOTH side port
