avrdude: stk500_recv(): programmer is not responding using Lilypad
I am on a Macbook Pro OS 10.5.8, updated to latest version of Java, LilyPad Mainboard 328, FTDI Basic Breakout board, using Arduino 0022 on serial port dev/tty.usbserialA-800cr8i
I can load the blink sketch and then when I upload the blink without delay sketch following or change the timing parameter blink sketch and try to upload, I get the following message.
Short Version avrdude: stk500_recv(): programmer is not responding
Long Version Binary sketch size: 994 bytes (of a 30720 byte maximum) /Applications/Programming/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Programming/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P/dev/tty.usbserial-A800cr8i -b57600 -D -Uflash:w:/var/folders/fT/fTB-Rl+CF9esGJrfh6RfaE+++TI/-Tmp-/build7288028815964016039.tmp/BlinkWithoutDelay.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 9 2007 at 11:20:31 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
System wide configuration file is "/Applications/Programming/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf" User configuration file is "/Users/kxxxx/.avrduderc" User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.usbserial-A800cr8i Using Programmer : stk500v1 Overriding Baud Rate : 57600 avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: ser_recv(): programmer is not responding avrdude: stk500_recv(): programmer is not responding avrdude: Send: Q [51] [20] avrdude: ser_recv(): programmer is not responding avrdude: stk500_recv(): programmer is not responding
I looked at the following threads to solve this issues as these people had the same problem, but not clear if the problem was solved.
http://arduino.cc/forum/index.php/topic,50929.0.html AND http://arduino.cc/forum/index.php/topic,28333.0.html
I have swapped out USB mini cable cable and the breakout board and the lilypad ( I have two of each), double checked the FDTI drivers making sure they are the latest ones, held down the reset button (even though I should not have to). I feel like it is something simple that I am not checking.
txt rxt blinks red when holding down reset on upload.
The green LED on the Lilypad blinks.
Any advice would be appreciated. Thanks.
I am having the same problem. I have tried troubleshooting many times and I still have the same core issue. After going through two Lily Pads I have been able to upload the blink program once and then I haven't been able to upload any other programs or even the same program again. I have tried using the reset button while uploading and it hasn't worked either. After scouring the internet I still haven't found a solution. Any help would be great!
Get an usbtiny. It works with the IDE, it is cheap, it does not require the presence of a bootloader, after correct setup it just works. Always.
Don't buy any of these: 'LilyPad Arduino Simple Board'. If the bootloader dies, you can throw it away or desolder the chip.
